Alfonso 15 #1 Posted July 13, 2016 (edited) Does anybody have info on the C120 Special as far as production. I was told they only made just under 400 of them. Edited July 13, 2016 by Alfonso Share this post Link to post Share on other sites
stevebo-(Moderator) 8,604 #2 Posted July 13, 2016 From what I have seen this model came with the tecky motor Share this post Link to post Share on other sites
muz123 1,193 #3 Posted July 13, 2016 Never seen one or knew they made one. Sounds interesting to see! Share this post Link to post Share on other sites
953 nut 64,189 #4 Posted July 13, 2016 18 hours ago, Alfonso said: C120 Special More often than not the "Special" was a with a non-standard engine because the usual supply of kohlers dried up and they needed to keep the line moving. Don't know that it would affect the value one way or the other. Like @stevebo said, some '74 and '75 C-120s came with a Tecumseh. Share this post Link to post Share on other sites
Bert 760 #5 Posted July 13, 2016 36 minutes ago, 953 nut said: More often than not the "Special" was a with a non-standard engine because the usual supply of kohlers dried up and they needed to keep the line moving. Don't know that it would affect the value one way or the other. Like @stevebo said, some '74 and '75 C-120s came with a Tecumseh. bout sums it up.... I'll add that some were C160's, not just C120's. 1 Share this post Link to post Share on other sites
tbarnhart 240 #6 Posted July 14, 2016 As I understand it, Kohler was not able to supply enough engines and Wheel Horse went to Tecumseh. In '74, some of the C-160 8-speeds and C-120 8-speeds and automatics came with the Tecumseh engines. They were made along with the Kohler powered tractors and were simply labeled as C-120 or C-160. The model numbers were different to correspond to the different motors, and the 160 hoods were raised up in the front to clear the taller OHV Tecumseh 16hp. In '75, they were back to all Kohler power except for a few C-120 8-speeds that were labeled as C-120 Special. Probably a pretty rare tractor, but I don't think any build numbers were recorded. I'd like to know how many '74 C-160s were made with the OH160 Tecumseh like the one I have. 2 Share this post Link to post Share on other sites
Retired Wrencher 6,466 #8 Posted July 14, 2016 8 hours ago, tbarnhart said: As I understand it, Kohler was not able to supply enough engines and Wheel Horse went to Tecumseh. In '74, some of the C-160 8-speeds and C-120 8-speeds and automatics came with the Tecumseh engines. They were made along with the Kohler powered tractors and were simply labeled as C-120 or C-160. The model numbers were different to correspond to the different motors, and the 160 hoods were raised up in the front to clear the taller OHV Tecumseh 16hp. In '75, they were back to all Kohler power except for a few C-120 8-speeds that were labeled as C-120 Special. Probably a pretty rare tractor, but I don't think any build numbers were recorded. I'd like to know how many '74 C-160s were made with the OH160 Tecumseh like the one I have. What Craig said. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,008 #9 Posted July 14, 2016 There were two 12hp Tecumseh powered models in 1975. The model 1-0357 was a Raider 12 and made in Belgium. The model 1-0375 was the C-120 Special and made in West Bend. Garry 1 Share this post Link to post Share on other sites
