powderfinger 24 #1 Posted July 7, 2016 I want to change motor oil and trans oil. what do you guys use? any other things I should check/do ? Share this post Link to post Share on other sites
stevasaurus 23,619 #2 Posted July 7, 2016 Download the manual in the "Manuals" section on the main page. I use 30wt in my Kohler and 90wt in the transmission. 2 Share this post Link to post Share on other sites
rmaynard 16,878 #3 Posted July 7, 2016 Motor oil Straight 30W Transmission SAE 90-140 A.P.I. Service GL-5 Gear Lubricant 2 Share this post Link to post Share on other sites
powderfinger 24 #4 Posted July 7, 2016 I pulled the manual on here. all it states is use 40 SAE in the transmission. i'm confused. in current lingo/specs, what does this translate to? Share this post Link to post Share on other sites
Racinbob 12,794 #5 Posted July 7, 2016 40w was recommended in the transmissions for a few years. They started suggesting it in order to minimize a shift rail issue that could cause it to lock in two gears. See service bulletin #55. Then they upgraded the rails but it took a couple of years for them to remember that the recommended oil be changed in the manuals. I've always used 80w90 1 Share this post Link to post Share on other sites
Mike'sHorseBarn 3,418 #6 Posted July 7, 2016 I always use SAE 30 in my engines and 90 wt oil in the transmission. Never have any issues with it. 2 Share this post Link to post Share on other sites
stevasaurus 23,619 #7 Posted July 7, 2016 @Racinbob...didn't we do a thread showing pictures of those shift forks so as to stop the confusion?? Share this post Link to post Share on other sites
Racinbob 12,794 #8 Posted July 7, 2016 Yes, we did Steve, Even had some goofball post some videos. I'm sure I can find it but no time right now. I will put out an APB as soon as I can. 1 Share this post Link to post Share on other sites
