erwine13b 27 #1 Posted July 2, 2016 I'm looking for a front mounted generator, or specs on how to build one of my own. i'm very interested in these, and would love to have one. 1 Share this post Link to post Share on other sites
wallfish 18,226 #2 Posted July 2, 2016 (edited) If you can't find an original, Pulley mounted generator head at HF. General rule of thumb is 2 hp of engine per 1000 watts but you don't HAVE to use it at full capacity. http://www.harborfreight.com/catalogsearch/result?q=generator+head You just need to build a platform to hold it. Edited July 2, 2016 by wallfish 7 Share this post Link to post Share on other sites
erwine13b 27 #3 Posted July 2, 2016 love it! i saw those, and liked them, but if i cannot find an original wh genny, i would like to build one but i need to find someone that has one to measeure out the mounting plates, mounting etc. Share this post Link to post Share on other sites
erwine13b 27 #4 Posted July 2, 2016 ok so i got some dimensions, but what i need to find out next is how many rpms a 10 hp kohler puts out at full throttle..... the research continues Share this post Link to post Share on other sites
wallfish 18,226 #5 Posted July 2, 2016 Should be set at 3600 rpm. You can also find cheap tachometers at HF to measure that. 3 Share this post Link to post Share on other sites
erwine13b 27 #6 Posted July 3, 2016 so how does a tach hook up exactly? Share this post Link to post Share on other sites
wallfish 18,226 #7 Posted July 3, 2016 (edited) Just a tool used to measure the RPM. http://www.harborfreight.com/digital-photo-sensor-tachometer-66632.html or search "tachometer hand held" on ebay for cheaper ones. Some contact, others don't. Edited July 3, 2016 by wallfish 3 Share this post Link to post Share on other sites
erwine13b 27 #8 Posted July 3, 2016 ok so i guess its supposedly set from the factory at 3600rpm, my buddy hooked me up with that digital tach, and it varies by 5rpm every once in a while but is right as 3600 for the most part. correct me if im wrong but with a 10hp i should be able to crank out around 5k watts? 18 hours ago, wallfish said: Just a tool used to measure the RPM. http://www.harborfreight.com/digital-photo-sensor-tachometer-66632.html or search "tachometer hand held" on ebay for cheaper ones. Some contact, others don't. walfish thanks for the great idea, i called my buddy frank aka the tool guy who has everything known to man lol. he hooked me up. thumbs up my friend, and ty for that tip! 2 Share this post Link to post Share on other sites
wallfish 18,226 #9 Posted July 3, 2016 You're welcome and just glad to be able to help! That's why we're all here and it's part of what makes this forum the best on the entire web. 2 Share this post Link to post Share on other sites
stevasaurus 23,300 #10 Posted July 3, 2016 Don't forget how much we love pictures when you get this set up. Share this post Link to post Share on other sites
wallfish 18,226 #11 Posted July 3, 2016 Sorry I missed the first question and just noticed it, Yes a 10 HP engine should be good for a consistent 5000 watts from the generator. Measure the PTO pulley and match that to a pulley for the generator so there will be a 1:1 ratio. Any difference in pulley sizes will change the RPM of the generator. 2 Share this post Link to post Share on other sites
erwine13b 27 #12 Posted July 3, 2016 ok so im assuming im using the outer pulley on my belt drive, and thats just from seeing pictures. how to i know the size of my pto, like measure lol im a major noob. or does someone already know? what the size of the pto pulley is i guess i should have clarified . Share this post Link to post Share on other sites
mmmmmdonuts 274 #13 Posted July 4, 2016 (edited) Yes it is the pto pulley that you need to match for a 1:1 on the generator. I don't want to confuse you but here is a pulley calculator size website. http://www.blocklayer.com/pulley-belteng.aspx This would be used if the pulleys are not the same size. In theory you could run a smaller pulley on the generator if you wanted to run the engine at a lower rpm. The problem is then you would lose some HP (and some kW) of the by not running full throttle. Edited July 4, 2016 by mmmmmdonuts Share this post Link to post Share on other sites
wallfish 18,226 #14 Posted July 4, 2016 (edited) If I remember correctly 4" inside groove ? 4.25" outside groove ? Edited July 4, 2016 by wallfish Share this post Link to post Share on other sites
Wildside 195 #15 Posted July 5, 2016 Erwine, I found this last week, it came with a bracket but don't know if it's right Bracket. 2 Share this post Link to post Share on other sites
erwine13b 27 #17 Posted July 5, 2016 message me please sir Share this post Link to post Share on other sites
WHX?? 51,877 #18 Posted July 5, 2016 Thats an old one and would look cool on the front of an RJ or Suburban!! ...just my would have to fab a bracket. What model tractor do you plan on putting one on erwine?? 2 Share this post Link to post Share on other sites
erwine13b 27 #19 Posted July 6, 2016 310-8 this one a 310-8 Share this post Link to post Share on other sites
