TimH 105 #1 Posted June 26, 2016 A couple weeks ago. I changed my gas lines , took out the messed up screen in gas tank. Added a inline fuel filter and took apart carb and cleaned. I did flush gas line before hooking gas line up to clean carb. Made sure float was adjusted right. So the problem I have is engine seems to act like it's running out of gas at time s. Only when the mower deck is engaged. Has a waboro carb on it. ? is Could it be in the carb adjustment ? Any suggestions on what to use if I want to install a electric fuel pump ? Thanks Share this post Link to post Share on other sites
N3PUY 1,031 #2 Posted June 26, 2016 Try opening the Hi-speed needle ¼ turn. And then maybe more or less. Share this post Link to post Share on other sites
TimH 105 #3 Posted July 2, 2016 Looks like I am going to have to find a new carb. I looked online But did not find one. May as well change the points and condenser to. Any clues on were to find these parts ? Share this post Link to post Share on other sites
scotty 252 #4 Posted July 3, 2016 (edited) Napa should have the points and condenser. Ive bought those from my local napa. It looks like eBay has some new carbs for the 12 hp kohler. Edited July 3, 2016 by scotty 1 Share this post Link to post Share on other sites
Lagersolut 795 #5 Posted July 3, 2016 There's a seller on the bay selling the carbs for 10 and 12 horse kohlers - if you can't find it PM me and I'll send you the link . Carbs are a little over $100 with free shipping . comes with both style choke shafts . Share this post Link to post Share on other sites
Aldon 4,832 #6 Posted July 3, 2016 Lots of eBay vendors. Last one I used was "Isavetractors" . Carb manufacturer or at least the name on the box it was in was BBT. 1 Share this post Link to post Share on other sites
Lagersolut 795 #7 Posted July 3, 2016 3 minutes ago, Aldon said: Lots of eBay vendors. Last one I used was "Isavetractors" . Carb manufacturer or at least the name on the box it was in was BBT. Last one I used and have saved is bakt4kids . Share this post Link to post Share on other sites
tunahead72 2,627 #8 Posted July 3, 2016 Tim, are you sure you need a new carb? You mentioned it only acts up when the deck is engaged, how does it run otherwise? Share this post Link to post Share on other sites
TimH 105 #9 Posted July 3, 2016 29 minutes ago, tunahead72 said: Tim, are you sure you need a new carb? You mentioned it only acts up when the deck is engaged, how does it run otherwise? It's running worse as time goes. Not going to take the time to rebuild carb or clean it again. One thing I have found over the years is Walboro carbs with little adjustment. You have to just replace them. Just going to get the guys to take it to our warehouse Tuesday and work on it this winter. Share this post Link to post Share on other sites
TimH 105 #10 Posted July 5, 2016 My local Toro dealer gad all the parts I needed except a fuel pump. Any one know were I could get a new pump or rebuild kit ? I am going to go ahead and do a valve job and re ring the engine while I have it removed and apart. Share this post Link to post Share on other sites
TimH 105 #11 Posted July 6, 2016 http://www.aircraftspruce.com/catalog/eppages/solidstatepump.php 1 Share this post Link to post Share on other sites
TimH 105 #12 Posted July 8, 2016 Just received new Electric fuel pump. I rebuilt engine and carb. new points and con. Runs like new now. 1 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,363 #13 Posted July 8, 2016 Tim , Which pump ( part number ) did you order? Share this post Link to post Share on other sites
TimH 105 #14 Posted July 8, 2016 1 hour ago, elcamino/wheelhorse said: Tim , Which pump ( part number ) did you order? 60300n 05-06862 60300 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,363 #15 Posted July 8, 2016 Thanks Tim for the information. 1 Share this post Link to post Share on other sites
