Indiana_Steve 125 #1 Posted June 21, 2016 WH 953 with a starter generator, seems to turn over slow although always starts. Is this "slowness" normal? Has new battery. I have had WH's in the past but always with the newer starters. I was thinking of rebuilding but wasn't sure if this starter has the bearings at both ends. I see some have a sleeve bearing. I'm not sure part wise if there is a lot of differences between older models with these types of starters. Share this post Link to post Share on other sites
squonk 48,167 #2 Posted June 21, 2016 They turn slow. If it isn't noisy and charges ok leave it alone. 1 Share this post Link to post Share on other sites
Indiana_Steve 125 #3 Posted June 21, 2016 OK I'll leave it alone. Thanks. It does start and charge. 1 Share this post Link to post Share on other sites
pfrederi 21,190 #4 Posted June 22, 2016 S/Gs turn the engine over more slowly than the more modern bendix drive starter units. Share this post Link to post Share on other sites
Lane Ranger 12,114 #5 Posted June 22, 2016 Clean the A terminal real well and you will be surprised how it seems to have a little more umph! 2 Share this post Link to post Share on other sites
