Thisguyisnew
Wanted a snoblower and got another C-160
Thisguyisnew
Engine was in pieces when it arrived and needed a new piston but all that aside After a new rear seal and adding oil test drove it the other day. It was a lot of work but I'm just so glad there wasn't more damage as the fins were packed with mud(could this have caused the piston failure?) I'm thinking this was not a normal buildup. Has anyone seen this? No way it was cooling properly.
And as a side note: I just wanted to send a shout out to Mabsoon for going out of his way and bringing both this and the snoblower down. ! couldn't have done it without you buddy.
AMC RULES
These little guys just love finding a :wh: left sitting outside.
https://en.wikipedia.org/wiki/Mud_dauber
Thisguyisnew
There was some of those too, but on the other side of the motor. I'm talking mud like it had been used for off roading caked in behind flywheel and deep in fins under sheet metal side of motor. Let that be a lesson to take of the covers every now and then. If this was some kind of a normal buildup you wouldn't think it was really that bad without doing so. I'm still not sure if that would have caused a piston to fail as there seems to be nothing else noticeably wrong with it now.
  • Similar Content
    • rustyedge1
      By rustyedge1
      The local place I’ve bought parts from for years has changed owners, now they can’t even spell Wheel Horse let alone be if any help.
      Doing my spring tune up I noticed my drive belt is getting pretty ratty. Due to all I’ve read thought I’d ask for some advise on getting it right the first time on a new belt.
      Is there still dealers on this site selling OME stuff ? I know there are tons of aftermarket crap but not looking for that.
      Thank in advance.
    • rustyedge1
      By rustyedge1
      Need a condenser for engine shown in photos 8 hp Kohler. Any venders carry them on this site ?
      All help appreciated..Have PayPal or can send check..
    • WheelPuke
      By WheelPuke
      I have my 25A fuse blowing every time I put a new one in the slot. The old one was burnt up when I got the tractor put this year. It sat for a year with a dead battery. I stopped using it as much because the transmission is clattering pretty bad when taking off on second or higher. I had to replace the clutch belt a few years ago and couldn't get an OEM. Not sure what is the problem there that's another issue though.
      I have checked the wiring and patched the worn spots where it could be grounding out. The fuse blows as soon as there is power to the system with the ignition off. I'm at a loss of what to check for at this point. Any input from someone who has had this issue would be appreciated. I'm not sure what these units are in the photos but do not know how to test them for a failure. They are directly in loop with the battery and the ignition loom looks to run into that 25A fuse.
    • Deer hunter
      By Deer hunter
      Does anyone know where I could find a complete engine rebuild kit from for the k-19 ? I absolutely love my c-195 and have had it for years. But the motor let go last fall and I want to rebuild it or upgrade the motor, any suggestions?
    • Redtickuleez
      By Redtickuleez
      Hello gentlemen!!! I recently bought a d180 with loader and backhoe. Im looking for serial number.. there is a plate under the steering wheel but its been pajnted over and i can make it out. Can y'all tell me another location and was this tractor pruchased originally with these attachments and any info would be greatly appreciated... Thanks fellow Wheel Horse enthusiasts !!! !! !!!
