goblbustr 9 #1 Posted June 17, 2016 Ok fellas, Got a good buy on a Brinly plow but as I have never used one I am trying to find out if my c160 hydro and c120 8 speed will handle it without tearing up my tractors. Any one ever use either of these with a plow? Thanks Share this post Link to post Share on other sites
stevasaurus 23,834 #2 Posted June 17, 2016 You will have no problem using a plow behind either one of those horses. That is what they live for. They are garden tractors. Does it look like this, or close?? You can pull this with a Suburban. 3 Share this post Link to post Share on other sites
squonk 48,051 #3 Posted June 17, 2016 8 SPD is the better choice. 1 Share this post Link to post Share on other sites
WHX?? 58,043 #4 Posted June 17, 2016 Hook up to either and GO!! Experiment with the gearing to find out what combo works best with your tires/soil type. Start with the 8 speed in low range. 1 Share this post Link to post Share on other sites
goblbustr 9 #5 Posted June 17, 2016 thanks for the info guys, it looks very much like that, stevasaurus. Cant wait to start turning ground. 4 Share this post Link to post Share on other sites
Shynon 7,656 #6 Posted June 18, 2016 6 hours ago, WHX61/3 said: Start with the 8 speed in low range I pull mine with a 12hp 8speed 1257 2nd gear high 5 Share this post Link to post Share on other sites
Achto 32,615 #7 Posted June 18, 2016 Hydro's are not usually the best choice for ground engagement implements. I would go with the gear jammer (8 speed) instead. Share this post Link to post Share on other sites
C-101plowerpower 1,606 #8 Posted June 18, 2016 i plow with a 12hp 4 speed in second. 3/4 throttle 3 Share this post Link to post Share on other sites
Tankman 3,528 #10 Posted June 18, 2016 Plowed many times, gear drive. Never a problem. Use plenty of front weight! 1 Share this post Link to post Share on other sites
