howard leavitt 0 #1 Posted June 13, 2016 My Wheel Horse My Wheel Horse needs a new fuel line and new inline fuel filter .....I thank anyone for any help to order same and advise removal / install procedures. Much thanks,Howardneeds a new fuel line and new inline fuel filter .....I thank anyone for any help to order same and advise removal / install procedures. Much thanks,Howard Share this post Link to post Share on other sites
shallowwatersailor 3,222 #2 Posted June 13, 2016 Hi Howard, to ! The best way to proceed is to look at how the old line runs. If it has fuel in the tank, close the valve where the fuel line exits the tank. Remove the cover over the shifters to access the middle of the tractor. Along the chassis you will find it clipped/clamped along the way. These will need to be loosened to replace the line. Try to place the filter in the same place as the old one and use hose clamps. Maybe someone who has this model tractor can post some detail photos for you. Share this post Link to post Share on other sites
wrightorchid 261 #3 Posted June 14, 2016 Since you will have to feed it through the middle of the tractor, and various holes and such, use a drill bit of other similar part to connect the old line with new, and you can pull the new line in easily. This worked well, and it did not get hung up, since the new line will have a natural curve to it. This topic should be in the tractor or other appropriate subject location in the forum. 1 Share this post Link to post Share on other sites
howard leavitt 0 #4 Posted June 15, 2016 On 6/14/2016 at 10:51 AM, wrightorchid said: Since you will have to feed it through the middle of the tractor, and various holes and such, use a drill bit of other similar part to connect the old line with new, and you can pull the new line in easily. This worked well, and it did not get hung up, since the new line will have a natural curve to it. This topic should be in the tractor or other appropriate subject location in the forum. Thanks much.....when your lost --- any road will do. Will follow your advice......sounds good to me. Again, Thanks much, Howard On 6/13/2016 at 5:35 PM, shallowwatersailor said: Hi Howard, to ! The best way to proceed is to look at how the old line runs. If it has fuel in the tank, close the valve where the fuel line exits the tank. Remove the cover over the shifters to access the middle of the tractor. Along the chassis you will find it clipped/clamped along the way. These will need to be loosened to replace the line. Try to place the filter in the same place as the old one and use hose clamps. Maybe someone who has this model tractor can post some detail photos for you. Thanks much for the procedures........will follow your advice.You have been a big help! Howard Share this post Link to post Share on other sites
