Southerncannuck 73 #1 Posted June 10, 2016 I worked in a tire shop years ago but I've never broken a bead without a Coats machine. Do you guys do it yourselves at home? Any tricks or is it sledge hammer persuasion? Share this post Link to post Share on other sites
SylvanLakeWH 31,051 #2 Posted June 10, 2016 Discount Tire... Worth the $12 to take off, discard and remount with tubes... Just did it for 4 tires after trying unsuccessfully... Don't ask me how I know what its like to buy another tube or two because I puked it putting it back on with a pinch of the tire irons... 1 Share this post Link to post Share on other sites
dells68 7,499 #3 Posted June 10, 2016 I've had good luck with the claw end of a pry bar and a heavy hammer. Just be careful not to damage your rim. Share this post Link to post Share on other sites
wallfish 19,723 #4 Posted June 10, 2016 (edited) One of these tire machines works great for the small tractor tires we use. Get a 20 or 30 % coupon. Plus wait until it's on sale and get it even cheaper. Well worth the small investment if you do just a couple of tires per year. The mini type works better for the smaller front tires http://www.harborfreight.com/catalogsearch/result?q=tire+machine I used to use a 2x4 with the tire flat on the ground and leveraged a pipe into the tow hitch on my van. It was a pain in the A-- but it worked.. Edited June 10, 2016 by wallfish 3 Share this post Link to post Share on other sites
WHX?? 56,030 #5 Posted June 10, 2016 26 minutes ago, dells68 said: Just be careful not to damage your rim. Or tire??? I have been know to drive over it with another ! There was just a thread/post about how he heated it up with a torch I'll go see if I can find it. John's way it best tho. 2 Share this post Link to post Share on other sites
dells68 7,499 #6 Posted June 10, 2016 Been lucky so far. Even managed to remove a set of original suburbanites without damaging them. The rims were eat up, so I wasn't so concerned with them. Share this post Link to post Share on other sites
lobo 23 #7 Posted June 10, 2016 Lay the tire on the ground, after you remove the valve stem, get a 4ft 2x6 and lay it on the tire at the edge of your rim, then drive your car or truck up on it. If it doesn't pop the bead then rotate the tire and try again. I've used this method on car tires also for years with great results. 2 Share this post Link to post Share on other sites
moe1965 774 #8 Posted June 10, 2016 I use my bench vice. One side on the edge of the rim and the other side on the tire. 2 Share this post Link to post Share on other sites
82Caddy 851 #9 Posted June 10, 2016 I use one of those attached to a 2in receiver hitch on one of my tractors or the truck. It works well and I've done 10+ tires with it now without issue. 5 Share this post Link to post Share on other sites
jimt1971 237 #10 Posted June 10, 2016 I use my Coates 40-40a tire machine. Sorry guys 2 Share this post Link to post Share on other sites
TDF5G 2,073 #11 Posted June 10, 2016 (edited) I've used a bottle jack under the receiver hitch on my pickup. If you have rusty old rims, it may be worth it to have them broken down at a tire shop. They can be a pain! Edited June 10, 2016 by TDF5G 3 Share this post Link to post Share on other sites
pacer 3,179 #12 Posted June 10, 2016 Another fan of that HF changer - the 40 odd $ for it is very much worth it even if for just one tractors 4 tires. Ive changed maybe 20 or so, IMHO the removal from the rim is not so good, but if I can get the bead broken loose I can go from there, and the HF will break the bead very well! 2 Share this post Link to post Share on other sites
Southerncannuck 73 #13 Posted June 10, 2016 Thanks everyone. Share this post Link to post Share on other sites
Rob R 989 #14 Posted June 10, 2016 Made one out of scrap iron and old garage door runners..... works like a charm. 14 Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,567 #15 Posted June 10, 2016 I pay a tire joint to do it. Its easy then. Glenn 5 Share this post Link to post Share on other sites
ohiofarmer 3,389 #16 Posted June 10, 2016 (edited) Tried the claw hammer way and it damaged the bead and still it remained stuck. Pretty extreme example of a stuck tire that had Fix-a flat used on it probably twenty years ago, just glued and rusted on.. If you heat about a 12 inch arc with a moving propane torch until you first see white smoke, they come off pretty easy. Just heat the bottom of the bead through the metal rim. On mine, the paint did not blister on the rim and the tire was not damaged either, The trouble with lawn and garden tires is the weakness of the sidewall just lets the bead breaker slide away from the rim. I used a pallet fork mounted to a skid steer Bobcat and it worked a treat. One stroke and the rest of it stomped right off. You can get the angle just right with another person positioning the tire. Edited June 10, 2016 by ohiofarmer 2 Share this post Link to post Share on other sites
JPWH 6,544 #17 Posted June 10, 2016 Before I got the HF mini tire changer I used a flat carpenters nail bar about 3/16 x 1 1/2" x about 12" long with about a 2" short 90 end. Tap the short end between the bead and the rim spray or apply soapy water near rim and rock the bar parallel with the rim. Repeat around rim every four inches or so. Never had to go all the way around before the bead broke loose. 3 Share this post Link to post Share on other sites
doc724 925 #18 Posted June 10, 2016 I read a while back where someone made a fixture out of wood ( 2x10 or 2x12) , scalloped to match the rim OD. He laid it on the tire and backed over it with his car. Same method Lobo cited but maybe a bit more elegant. Don't know if it works any better though, 1 Share this post Link to post Share on other sites
russellmc301 601 #19 Posted June 10, 2016 i feel just having someone do it is the best, unless you know what you are doing. just my Share this post Link to post Share on other sites
KC9KAS 4,746 #20 Posted June 10, 2016 (edited) I have/use this one. Search the www for "home-made" tire changers. It you are handy fabricating, you can build a nice heavy duty one. Edited June 10, 2016 by KC9KAS 2 Share this post Link to post Share on other sites
ACman 7,715 #21 Posted June 11, 2016 Reminenceing , back in the day working in the AC dealership. I had this May Bros tire changer, has shrader valves on top of post for clamping rim , and another shrader valve on top of bead breaker for busting down tires . My tire mounting , dismounting tool looked just similar to the one in the picture ( standing up right blocking the view of the cogs that clamp the rim ) . The he other must haves are tire spoons with a drop center and a 4LBS dead blow hammer . I was taught by an old timer, had lots of tricks. I sure did my share of tires back in the day . 1 Share this post Link to post Share on other sites
Tuneup 1,453 #22 Posted June 11, 2016 I love the car use idea. I use vacuum from the car to bleed brakes through a pickle jar. For breaking beads on motorcycle and now tractor tires, a 6' 2x4 I attach through a hinge to the garage wall. About 2' from the wall, a 2x4 pivot is attached to the main by a bolt. I lay the tire on the floor and push on the end. Easy, peasy. Have used this one for years. When done, I remove the 3 hinge screws and store it in the corner. 1 Share this post Link to post Share on other sites
pfrederi 20,243 #23 Posted June 11, 2016 I have the small and large HF tires devices...Also have used several other bead breaking devices...but hands down this type slide hammer is the best. Does all my tires from the 16- 5.5x8 front WH tires to the 13.6x38 on my Case DC3 1 Share this post Link to post Share on other sites
953 nut 65,168 #24 Posted June 12, 2016 11 hours ago, ACman said: May Bros tire changer, I used one just like that when I worked at a service station while in high school, over 50 years ago. Worked great. 2 Share this post Link to post Share on other sites
can whlvr 994 #25 Posted June 12, 2016 so years ago I tried the wood on the tire and drive on it,well the tire flipped up and smashed my air dam and I had to remove it,now I use a large c clamp,ive broken dozens with it and even skid steer tires are no match for it,use dish soap to help it slide 1 Share this post Link to post Share on other sites
