nickj21 20 #1 Posted June 8, 2016 Ran into some problems with my charger 12 resto. I redid all the wiring and now nothing happens when i turn the key over...i did one wire at a time making sure it was right..now somethings wrong and i cant figure out what..thanks for the help!! Share this post Link to post Share on other sites
squonk 48,166 #2 Posted June 8, 2016 Is there an ammeter? Everything goes thru that first. If it is shot, nothing will work. Share this post Link to post Share on other sites
pfrederi 21,185 #3 Posted June 8, 2016 (edited) Time to get out the multimeter. Do you have voltage at the B terminal on the switch? Note be very careful testing, you really should use fully insulated connectors on the back of the switch. It would be easy to touch 2 terminals at once and if you have a breakeless ignition system you could fry some expensive parts. Edited June 8, 2016 by pfrederi 1 Share this post Link to post Share on other sites
Racinbob 13,200 #4 Posted June 8, 2016 It's pretty hard to figure out what's wrong without seeing it. First, as Mike said, check the ammeter if it has one. Then, with a meter or test light take it one step at a time following the wiring diagram. What year is the tractor so you are working off the correct diagram. 1 Share this post Link to post Share on other sites
moe1965 774 #5 Posted June 10, 2016 Bad safety switch wold be my first place to start. Start simple and go from there Share this post Link to post Share on other sites
