ronhatch 407 #1 Posted June 8, 2016 (edited) I've been working my way through several minor problems with my newly restored C-101 this mowing season. One of the last issues is the concentration and clumping of the grass clipping exiting from the deck discharge especial if the grass is a little long. I've been mowing every 4 days just to keep the clumping to a minimum. I solved the same problem several years ago on my '66 B-10 AC by making a 6" cut in the top of the deck starting at the discharge opening and close to the front edge. I then bent the front edge forward about 3" and then welded a pie shaped piece of metal in the resulting 'V' gape. This opened the discharge which allowed the grass clipping to exit in a very nice fan pattern. Has anyone else solved this problem in a simpler way? Maybe adding 'wings' to the right/last blade? roadapples and elcamino/wheelhorse like this Quote Edit Edited June 8, 2016 by ronhatch 1 Share this post Link to post Share on other sites
tarcoleo 119 #2 Posted June 17, 2016 (edited) Great idea. Have the same problem with my 48" SD decks. Got pictures? What about the cross piece at the exit of the deck. Do you use the chute extension? Thanks in advance. -Tom Edited June 17, 2016 by tarcoleo Additional questions. Share this post Link to post Share on other sites
JC 1965 1,532 #3 Posted June 18, 2016 I have the same problem with my 42" side discharge mower deck. Very interested in your fix. Keep us posted and Share this post Link to post Share on other sites
