scraper 4 #1 Posted May 29, 2016 My 93 314 hourmeter and voltmeter stopped working. I checked the fuses and they seem to be O.K. The electrical system is my least knowledgable area for repair. Where do I begin to troubleshoot? Share this post Link to post Share on other sites
SylvanLakeWH 30,509 #2 Posted May 29, 2016 Start with verifying all the connections are sound. Clean them all and see if that does it. I have had luck with that simple advice in the past... Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,990 #3 Posted May 29, 2016 One of these may help 314-8 314-H Garry Share this post Link to post Share on other sites
squonk 45,402 #4 Posted May 29, 2016 Check to make sure you are actually getting power to each. Looks like they share the same fuse. A fuse may look good but it doesn't mean your getting power from it. 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #5 Posted May 29, 2016 Voltage regulator? I know it's a Kohler but that's what's usually wrong when they don't work on the Onan powered machines or just simply a loose/ corroded connection there abouts,Jeff. Share this post Link to post Share on other sites
Racinbob 12,706 #6 Posted May 29, 2016 51 minutes ago, squonk said: Check to make sure you are actually getting power to each. Looks like they share the same fuse. A fuse may look good but it doesn't mean your getting power from it. Definitely the first thing to do. Don't rewire the house when it's just a burnt out light bulb. If that's good make sure the ground is good and then, following the diagram, test it one step at a time. With the key in the run position power at the switch, the load side of the fuse, the terminal strip etc. until you find where the power is lost. 1 Share this post Link to post Share on other sites
