Bud Rig
48" mower deck for 414-8 WH 15-48sc01?
Bud Rig
Looking to buy a new deck for my 414-8, somebody said there is an aftermarket one out there, would prefer nice old oem, mine has been patched and patched again. Used POR 15 on a deck for my 314-8 a few years ago when I bought it and it has really held up well, anybody that has a 48" to sell or knows where I can find one would be appreciated. Thanks, Brad
  • Similar Content
    • HyperPete
      By HyperPete
      1973 16 HP horse with FEL & weight box (box just sandblasted & painted) Seat has a single 2 - 3" tear, taped. It's got a (42?" ) deck & mule, and the FEL stands go with it.
      I'm taking the new rear AGs & weights off and putting turfs back on.
      Recent service includes trans service (Wix filter), oil change, new plug, new choke cable, carb cleaning, and FEL fluid change.
      I also have a 2nd frame/body to include.  Needs a headlight, I believe I have it.  Driving lights on FEL.
      NOTE:  I need time for my hand/wrist to heal before I can swap the rear wheels and tires.
      EDIT:  I added photos of the wheels and tires that will go on the back of and a couple of partial photos of the repainted weight box.
      9
    • WheelPuke
      By WheelPuke
      I have my 25A fuse blowing every time I put a new one in the slot. The old one was burnt up when I got the tractor put this year. It sat for a year with a dead battery. I stopped using it as much because the transmission is clattering pretty bad when taking off on second or higher. I had to replace the clutch belt a few years ago and couldn't get an OEM. Not sure what is the problem there that's another issue though.
      I have checked the wiring and patched the worn spots where it could be grounding out. The fuse blows as soon as there is power to the system with the ignition off. I'm at a loss of what to check for at this point. Any input from someone who has had this issue would be appreciated. I'm not sure what these units are in the photos but do not know how to test them for a failure. They are directly in loop with the battery and the ignition loom looks to run into that 25A fuse.
    • nylyon
      By nylyon-(Admin)
      I think I am selling my 1987 414-8 with plow, weights and chains.  Now here’s the story on this one. A long long time ago, I was searching for a snow plow for my 416H.  In that search I stumbled onto a forum which was one day old.  There was no name of the forum, just whtractor.15.forumer.com. Trying to learn more about snow plows I started conversations with one of the active members on the site, let’s call him Mike.  Mike convinced me I didn’t need a plow, but an entirely new tractor.
      About a week or so later, I found this 414–8 for sale, and bought it.  I now had my plow and could plow the driveway. So what happened with Mike @Sparky and this forum I spoke of? It grew a little bit, and we now call it RedSquare, and for sale is one of if not THE reason RedSquare exists today, so you can own a piece of RedSquare history!
      About the tractor: 1987 414-8. Kohler M14, runs well does not burn oil. Everything on the tractor works as it should, but it is a worker. The plow is a 48” with a custom made scraper blade, made from heavier stock than original. For the past several years, this has been a dedicated plow tractor, so it hasn’t seen a lot of work, but has also sat outside (under a tractor cover) so lots of let’s say, patina going on.
      I a, selling because I just picked up a 416-8, and that will become my winter plow / blower tractor.  I am looking for $550, but like I said this tractor is a bit of a legend!
      I have cleaned it up since the pictures were taken.
    • F. Marra 17
      By F. Marra 17
      Gets the job done
    • F. Marra 17
      By F. Marra 17
      No problem cutting through
