Thisguyisnew
The most clever Homemade implement you've seen
Thisguyisnew
What's out there that should have been made by Wheel Horse but wasn't?
Rob.A.700
I dont have a picture of one but the leaf blowers people have made out of furnace blowers and mounted to the front of there horses they are pretty neet.
RedRanger
Ash trays to go with the cig lighters?
Thisguyisnew
A cultivator made from the tops of propane tanks was what I first saw online. Darn thing looked pretty easy to make to.
tbarnhart
Not claiming its the most clever, but I like my pressure washer attachment. I detailed it here.
Lane Ranger
A front trailer hitch  made to fit in attach-a-matic  (using old mule drive)  !   A really neat  attachment and works way better than a ball on the back of the tractor !
  • Like 6
Lane Ranger
Not an implement but an attachment that works great on 1054 Wheel Horse tractors!
A rear drarbar hitch  that is made to allow the slot hitch to also work  in conjunction with the  mgallery_339_37_401596.jpggallery_339_5_770663.jpgulti-holes in the drawbar for pulling , etc
dells68
Now that's what I'm talking about!B)
WHX??
That is the best tbarn!! :handgestures-thumbupright: No more wheeling the darn thing around. Best thing about a washer is it is easy to get out and get going...you just made that a whole lot easier!
I'm sure it has been done but can find a pic...... a log splitter
WHX??
Aldon
So far my vote would be for the chicken plucker....There was a thread on the forum for it.
dells68
Wow:blink:!  All I can say is I'd hate to be a chicken in that thing!  It was awesome!!!!!
Ed Kennell
Here's a couple of mine.
                                                          Mad Max Tiller
Foot  controlled motion
Snow plow stabilizer and height control
  • Like 8
Digger 66
They should have made an adjustable height sickle bar so those lonnnng hedge-row tops could be impeccably   F  L  A  T
can whlvr
not an implement but a handy thing to have
  • Like 6
Digger 66
Maybe not the most creative implement but the 'ol girl makes a nifty plant stand .
With some nasty T-storms on the way this evening , I elected to wheel the peppers into safety & the :wh: just happened to be in the right spot .
  • Like 5
brandonozz
Here is a "depth Guide" I found on a parts D I picked up.  The slide to the right of the driver has marks to indicate how low/deep your attachment is.
  • Like 6
CasualObserver
Well, the Chicken plucker  should definitely be in this list!
semper5
So far, my only mod...
Mean looking.
  • Like 8
elcamino/wheelhorse
What do you use the blade with teeth for ?
Phatboy
Looks like it would be good for getting rocks out of a new garden plot
Or using it for gravel drive way ,, or for digging with blade us the teeth to losen up the ground, sort of like a ripper,, thats a good idea for a back blade,, put bunch of teeth on it like a ripper then push with front blade,,
semper5
So far I have:
Pushed hot ashes and spread them
Knocked down chest-high weeds in the back forty before mowing them
Spread ground tree trunk where the chunks were about the size if a man's fist
Pushed large rocks
Dragged it backwards, roughed up the soil, and planted grass seed
Pushed a very large pile of leaves from the back of the house to the tree line, 35 yards away
There's more, I;m sure...
WHX??
Now that's a ground engaging implement!
  • Similar Content
    • rustyedge1
      By rustyedge1
      Need a condenser for engine shown in photos 8 hp Kohler. Any venders carry them on this site ?
      All help appreciated..Have PayPal or can send check..
    • WheelPuke
      By WheelPuke
      I have my 25A fuse blowing every time I put a new one in the slot. The old one was burnt up when I got the tractor put this year. It sat for a year with a dead battery. I stopped using it as much because the transmission is clattering pretty bad when taking off on second or higher. I had to replace the clutch belt a few years ago and couldn't get an OEM. Not sure what is the problem there that's another issue though.
      I have checked the wiring and patched the worn spots where it could be grounding out. The fuse blows as soon as there is power to the system with the ignition off. I'm at a loss of what to check for at this point. Any input from someone who has had this issue would be appreciated. I'm not sure what these units are in the photos but do not know how to test them for a failure. They are directly in loop with the battery and the ignition loom looks to run into that 25A fuse.
    • Redtickuleez
      By Redtickuleez
      Hello gentlemen!!! I recently bought a d180 with loader and backhoe. Im looking for serial number.. there is a plate under the steering wheel but its been pajnted over and i can make it out. Can y'all tell me another location and was this tractor pruchased originally with these attachments and any info would be greatly appreciated... Thanks fellow Wheel Horse enthusiasts !!! !! !!!
    • Aaron Coffman
      By Aaron Coffman
      Hi Red Square Community,
      I am looking into purchasing the below pictured "POND" Walk Away. The unit itself has the cast in “POND” on the chain reduction housing. The two main things I am looking to learn are what value is typical for these to sell for. This one has a Briggs & Stratton model “N” engine. It runs and drives, but the throttle linkage needs some adjusting. It comes with a cultivator and plow implement.
      Secondly, I was wondering if there is any way to determine what year specifically this Pond is from. The seller believes late 1940s and not 1950s. I am new to these machines, so I am looking for some guidance. Thank you in advance!
    • ohiofarmer
      By ohiofarmer
      i know that there is ebb and flow with market conditions, but I have been seeing bargain 520 and c-160 prices more common. I recently saw a c-160 like model on a place other than here that was close by, but i did not get a chance to see it as I was still on a medical tether getting care. i say c-i60 like model because it was a series of numbers like 4455 or somesuch .Tractor had the k series engine clearly a sixteen HP and came with a decent looking deck and pusher blade. i called my buddy Jay and told him for the $250 ask , he better hustle after it. i really do not know if he did.
        I also have been seeing 520s and such lower than I can remember as well as the D series..My theory is that people experiencing paycheck to paycheck living are increasing in number.
      You even are seeing a lot more older trucks like square bodies and especially big blocks than you did before. we used to see this a lot in new trucks when fuel prices hit records.
      i am not claiming expert status on this, but it seems to be trending this way one county next to indiana and 90 miles North of the Ohio River.
       Tell me what you are seeing out there and what you think.
           Edit:  Jay and I ran up to buy Bob Ellison's tractor in MI.  Bob was very nice to deal with and included his "last seat"   I got super lucky buying my first C-160 that did not start and another one shortly dropped in to keep it company. The tractor described above was listed for only two days and was gone
