north
C81 where to start
north
I just picked up a c81 with a mower deck and plow for $300..not sure if it runs but looks good.  I washed it up and 1st step is a battery...any suggestions on how I should proceed or what to look for?  Or if it was worth $300?
thanks
Edited by north
  • Like 5
Rob R
Think you did GREAT C81 my favorite tractor....not so much for the mower... but it is a bear for pushing snow and doing chores around the property, good fuel, clean carb and a good set of points and you will have one (in my opinion) one of the best machines made.
  • Like 8
SylvanLakeWH
:text-welcomeconfetti: to the WH "C" club!
AMC RULES
    :text-coolphotos:     :handgestures-thumbsup:
:WRS:
Retired Wrencher
North. :WRS:  Looks good in picks. Get a battery from Walmart or Home Depot same price. just to see if you have spark. Then maybe change the fuel lines and filter. Buy good fuel line $3.00 to $4.00 a foot, start it  and see where you are at. Let us know how things are.
Tankman
Three hundred bucks well spent! Check, change fluids, fuel, cleanup and you'll be on your way!
Nice Horse and I bet, ready rarin' to wo...wo....WORK!  :handgestures-thumbupright:
Racinbob
That looks like an outstanding deal. As already suggested I would do a tune up, fuel lines and filter, fresh fuel, engine oil, flush transmission and fresh oil.:)
DougC
Hello and :text-welcomeconfetti: north!   Enjoy the forum and the new  :wh:.
roadapples
As others have said, good buy. plow and chains are worth half that, and....  :WRS:
JPWH
:WRS:
TDF5G
I'd say you gotta a sweet deal on your horse!  She's definitely worth putting a few $ in to get her going.  Looks complete except for air filter and cover.  And you'll need a couple of mower deck wheels.
With a little diagnosis you should have her runnin' in no time.  After you get a battery hooked up, check for spark and compression.  Then go through the fuel system.  I don't know how long it's been setting, but I would check the shutoff valve in the bottom of the fuel tank for rust and crud before putting any gas through it.
:WRS:
Edited by TDF5G
north
Fresh fluids and a new battery!  Onto the mower deck
IMG_2904.MOV
  • Similar Content
    • Tim's Toy Tractor
      By Tim's Toy Tractor
      Seat, New! Universal Garden Tractor / Riding Mower Seat
      This is a new seat that I purchased for a project tractor and never used, it is in Perfect as New Condition.
      I have used this seat on a few Wheel Horse tractors, and they have been a perfect fit and look great.
      This is a Universal fitment seat; it has multiple mounting holes and mounting patterns for fitment on most Graden Tractors and Riding Mowers.
      $49.00  Call Tim @ 1-313-460-8858     (Local Pick-Up Only, No Shipping)
    • Tim's Toy Tractor
      Two 3 Rib Firestone Tires, 16x6.50-8, 2 of them mounted on OEM Wheel Horse Rims, NEW!
      These tires are New, Never Used! Not the cheap China ones, these are High Quality Firestone Tires!
      Great for any Garden Tractor or Riding Mower
      They are mounted on original Wheel Horse wheels that have been sandblasted & epoxied, and painted with ivory colored paint, note there are a few chips along the inside bead from mounting the tires. The rims will need your specific size wheel bearings installed.
      $99.00 Call Tim @ 1-313-460-8858        (Local Pick-Up Only, No Shipping)
    • Tim's Toy Tractor
      C - Series, Hood and Sheet Metal (square black insert) (also known as black hood models) for sale!
      This sheet metal set, including C Series Hood, Dash piece, Seat Bracket, and Left & Right-Side Covers, and Left & Right Floorboards was sandblasted, epoxy primed, and painted the OEM Wheel Horse Red Paint.
      The painted set is not perfect, a little metal pitting on one of the floorboards, a few little imperfections in the paint here and there as I'm a rookie painter, but this is a nice painted set of sheet metal to freshen up your C Series Wheel Horse!
      $140.00 O.B.O. Call Tim @ 1-313-460-8858        (No Shipping, Local Pick-Up Only)
    • Deer hunter
      By Deer hunter
      Does anyone know where I could find a complete engine rebuild kit from for the k-19 ? I absolutely love my c-195 and have had it for years. But the motor let go last fall and I want to rebuild it or upgrade the motor, any suggestions?
    • BrianStasC-101
      By BrianStasC-101
