nws024 0 #1 Posted May 21, 2016 I'm back. I received alot of help with my clutch problem, thanks for that. Aparently my dad and I did not put grease in the center pulley, nor did previous owners by the looks of the bearing. The pulley snapped and came off. I have pulled it apart and I think it all needs to be replaced. I can take pics if that will help. I need ideas for replacement parts. Toro dealer claims they might be able to match. My tractor is C195. Sometimes tough to find parts. Thanks for y'alls help Share this post Link to post Share on other sites
953 nut 69,844 #3 Posted May 21, 2016 Not knowing what year or model your mower deck is makes it hard to help you. Go to the manuals section, select the mowers section and then do a search for "60in 19XX" (your year) and it should give you the manual for your mower deck. Find the part # and then post a Wanted add in our classified giving year, model and part number. Share this post Link to post Share on other sites
stevebo-(Moderator) 8,742 #4 Posted May 21, 2016 Aldon may have some parts for you. I sold him a deck with a bunch of extra moving parts however he is yet to pick them up. Parts for that deck are not easy to find (ask me how I know)... 1 Share this post Link to post Share on other sites
Aldon 4,833 #5 Posted May 22, 2016 That 60 inch style deck came on the C195's for sure. Maybe others. But knowing that they were on C195's will help you navigate parts tree and RCPW for parts diagrams and availability. It's likely going to be 3-6 weeks before I am at a point of knowing what I'll need and what I can spare from the trove of parts I'm getting from Stevebo. Share this post Link to post Share on other sites
cheesegrader 436 #6 Posted May 22, 2016 You are a better man than I am if you got that apart without a torch or explosives. I have a 05-60SC01 (1983 60") off a C195 now on a 520. Toro dealer was useless when looking for parts for a 33 year old deck. I got a second 60" deck for less than the cost of parts for one spindle. Share this post Link to post Share on other sites
nws024 0 #7 Posted May 22, 2016 C195 was only 1983 ,84 I believe. Mower deck has a # 109799. I think that's the part #. I will post in want ads. Thanks for the encouragement, guess I'm going to wear that walk behind weed eater out. Share this post Link to post Share on other sites
cheesegrader 436 #8 Posted May 22, 2016 I think 109799 is the serial number of that individual deck, not the model number (my serial number is only 5 digits, 10098) The model number that you need to hunt for parts should have a "60" in it somewhere. 05-60SC01, 05-60SC02.....something like that depending on the year it was made Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,511 #9 Posted May 22, 2016 109799 is a decal showing the belt routing and height adjustment. It was once stated that Ariens supplied this deck. Wonder if that is a parts source? Garry Share this post Link to post Share on other sites
Aldon 4,833 #10 Posted May 22, 2016 Perhaps from dealer stock. But from online it's was no additional help. Share this post Link to post Share on other sites
