LFR
The little C-81 work horse runs and drives good!
LFR
Here's the video
Edited by LFR
JERSEYHAWG /  Glenn
Lookin good, but she needs a little more luvin. Keep up the good work.
Glenn
neil
Great vid, those C81 tractors are really quite powerful & will do some amazing hard work .
thanx for the Movie
TDF5G
:text-goodpost:
Umm.... you've got a great project there.  Umm... a little TLC and she'll make a fine worker.  The umm.... deck shell is toast, I wouldn't try to mow with it either.  Too umm.... dangerous.
Oh, and umm..   great video.  Have fun with your new :wh:!
:text-bravo:
Tankman
Excellent Horse, certainly a worthwhile project. :handgestures-thumbupright:
Be sure to post updates, the forum is all for you and your Stallion!
  • Similar Content
    • Deer hunter
      By Deer hunter
      Does anyone know where I could find a complete engine rebuild kit from for the k-19 ? I absolutely love my c-195 and have had it for years. But the motor let go last fall and I want to rebuild it or upgrade the motor, any suggestions?
    • BrianStasC-101
      By BrianStasC-101
    • HumbleHans
      By HumbleHans
      Operator manual 810343R1
      Wiring
      34 pages 17.5MB
      Wiring Colored
      1 page 228KB
      1984 C-105 8-Speed model 11-10K802
      1984 C-125 8-Speed model 11-12K802
      1984 C-145 Automatic model 11-14KE01 - Some used alternate inner axle bearing See PSB #369
      1984 C-165 8-Speed model 11-16K801
      1984 C-175 Twin Automatic model 11-17KE01 - Some used alternate inner axle bearing See PSB #369
      1984 C-195 Twin Automatic model 01-19KE02
    • t_furl43
      By t_furl43
      1979 c-101 nice project tractor just needs a few odds and ends, steering wheel, coil, carburetor bowl, the wiring was redone by previous owner....all 4 tires are good and hold air it goes into all gears no problem, transmission fluid has been changed, 10hp Kohler, message me or call or txt with any questions, it does run and runs well,  it’s been kept inside since I’ve had it, I would also trade for a mid mount grader blade thanks
      92DB561C-FF95-4868-A52B-5725D4D3B9DE.mp4
    • RJ Hamner
      By RJ Hamner
      Will the plow I am using on my C121 and C160 work on a 876?
      or is the plow frame different?
      Thanks
      Bob
