Jp southwick
mis firing 1974 B-80
Jp southwick
so with your support I'm gaining on getting my tractor up and running thank you
so where I'm at now is, the ignition is finally wired correctly thank you, installed new points and adjusted them to .020, have new solenoid and coil and the tractor fires up but is mis firing. what would the next thing I should try?
