19richie66 17,816 #1 Posted May 7, 2016 So I have a Sundstrand hydrostat from a C175 I put in my cruiser. It had the hydraulic deck/ lift cylinder/ valve assy also. If I desired to put power steering on this thing, could I use the lift cylinder for a steer cylinder? I have a 5 port rotary steer valve and was wondering if I could plumb it to the ports where the hoses came out of the pump? (where the red circle is)? I have searched but only found info on the Eaton and it was vague. Thanks in advance, Richie 2 Share this post Link to post Share on other sites
953 nut 64,271 #2 Posted May 7, 2016 Can't see why it couldn't be done, just as good as any other two way cylinder. You may have to experiment with Pittman arm length and play with bypass pressure to make sure it is a smooth movement. 1 Share this post Link to post Share on other sites
19richie66 17,816 #3 Posted May 7, 2016 Ive been reading Kelly's thread about his diesel C195 with power steering but its an eaton so its a hair different. I could run a small GM power steering pump off the motor but I have those ports there already. Guess I'll dig through the sundstrand manual a little more. Share this post Link to post Share on other sites
953 nut 64,271 #4 Posted May 7, 2016 11 hours ago, 19richie66 said: 5 port rotary steer valve What did the valve come from? If pressures are the same as the Sundstrand it should be fine. Share this post Link to post Share on other sites
19richie66 17,816 #5 Posted May 7, 2016 It's still on my JD gt345. I don't think it will make it through another mowing season. If not, the power steering is going on my cruiser or the 418-A. Just was wondering about the sundstrand. Manual says 500-700 psi for the pump and the rotary valve is good for 1500-1800 psi. I think it would work. Found the port layout on both. Just a matter of mounting all the parts. Share this post Link to post Share on other sites
otrelwood 32 #6 Posted October 6, 2016 my air horse articulates with twin cylinders a little longer than the lift cylinder and runs off a sunstrand pump works fine Share this post Link to post Share on other sites
82Caddy 851 #7 Posted October 6, 2016 I have a 5 port JD column in a d series (also sundstrand) and it works without issue. Keep engine rpms up and it works great. Tractor has a loader on it so steering is a bit difficult anyhow. 1 Share this post Link to post Share on other sites
19richie66 17,816 #8 Posted October 6, 2016 Thanks guys! Share this post Link to post Share on other sites
clueless 3,348 #9 Posted October 6, 2016 Rich, ask your blue R2 unit, it could crunch the numbers and tell you what you need. Happy birthday, and hang in there Friday. Chris. Share this post Link to post Share on other sites
19richie66 17,816 #10 Posted October 6, 2016 Thanks Chris! Should be good. A project for another day. Share this post Link to post Share on other sites
smoreau 658 #11 Posted October 6, 2016 Not a issue at all. I have the same steering from a JDJthat will some day make it on my loader tractor. Double flared brake line with the correct nuts will work fine for pluming the bottom of the valve accept for the cylinder lines. Also the stock cylinder is a little short on stroke to do the power steering for my forward swept front axle, never tried it anything else. Share this post Link to post Share on other sites
19richie66 17,816 #12 Posted October 6, 2016 If I do it, I will use the JD axle and hubs with the cylinder and all. Ill keep the measurements close to whats on the deere. Other than making a cylinder mount and hoses, should be good. 1 Share this post Link to post Share on other sites
