Jp southwick 1 #1 Posted May 6, 2016 so I fryed my ignition when jump starting it, so I changed that. now I don't have spark which is the first time I've ever had this issue. so far I've changed coil, Solenoid, and PTO safety switch. it seems I can't get 12volts to the coil or points. any idea's I don't have lights and can't find any fueses at all on this tractor. Share this post Link to post Share on other sites
rmaynard 17,411 #2 Posted May 6, 2016 Try removing the two wires from the back of the ammeter and connect them together. If that's not the problem, it may be your ignition switch. Share this post Link to post Share on other sites
Jp southwick 1 #3 Posted May 6, 2016 I just replaced the ignition switch with a new one. i'll try connected the wires in the back of the amp meter. if that works does that mean the amp meter is bad? Share this post Link to post Share on other sites
rmaynard 17,411 #4 Posted May 6, 2016 Yes, all low amperage 12 volts goes through the ammeter. See diagram below: And be sure that the ignition switch that you got is for battery ignition and not magneto. Magneto will have and M lug on the back. Looking at the wiring diagram, the ignition does not go through any safety switch. 2 Share this post Link to post Share on other sites
Jp southwick 1 #5 Posted May 6, 2016 ok i'll check this out thank you Share this post Link to post Share on other sites
TDF5G 2,074 #6 Posted May 6, 2016 1 hour ago, rmaynard said: Yes, all low amperage 12 volts goes through the ammeter. See diagram below: And be sure that the ignition switch that you got is for battery ignition and not magneto. Magneto will have and M lug on the back. Looking at the wiring diagram, the ignition does not go through any safety switch. Make sure the ignition switch is wired correctly. Share this post Link to post Share on other sites
Jp southwick 1 #7 Posted May 6, 2016 my safety switch at the PTO is wired different than this diagram. everything seems to be wired thru it, the clutch safety, seat safety, ignition etc? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,325 #8 Posted May 6, 2016 What is the model and serial number on the tractor ID plate? Perhaps yours is wired like this one Garry Share this post Link to post Share on other sites
Jp southwick 1 #9 Posted May 9, 2016 that worked, the ignition was mis wired, thank you 1 Share this post Link to post Share on other sites
