buffaloman 295 #1 Posted May 2, 2016 Ok ,So I had the 702 put back together and running , even drove it around the yard for a little but every time I would try to take it off of choke it would stall out???? any troubleshooting ideas ? Share this post Link to post Share on other sites
woodchuckfarmer 333 #2 Posted May 2, 2016 Clean the carb again. 1 Share this post Link to post Share on other sites
Shynon 7,604 #3 Posted May 2, 2016 Just now, woodchuckfarmer said: Clean the carb again. Share this post Link to post Share on other sites
N3PUY 1,031 #4 Posted May 2, 2016 open the needle valves more Share this post Link to post Share on other sites
buffaloman 295 #5 Posted May 2, 2016 Thanks i will try both Share this post Link to post Share on other sites
stevasaurus 23,752 #6 Posted May 3, 2016 If you are running with the choke, you are either sucking air some where...or you are restricting the fuel flow (clogged fuel filter, clogged gas line)...that is why you need to choke. 1 Share this post Link to post Share on other sites
rmaynard 17,443 #7 Posted May 3, 2016 Hey B-man, pull that choke out and drive 'er on down here to Westminster. Stop by the Pepperidge Farm outlet store on your way and pick up some Asiago Cheese bread and a bag of Goldfish. By the time we finish off the goodies, I'll have you all fixed up and ready to go. All seriousness aside, you are starving for fuel, either low flow from the fuel pump of something clogged or not set right in the carburetor. Share this post Link to post Share on other sites
