howell1000 35 #1 Posted April 26, 2016 I have a sk 486 with kohler 16 horse put new stater and battery now it burns fuse and when i get it to work the bendix on starter will not go out far enough to turn over engine PLEASE HELP Thanks Share this post Link to post Share on other sites
c-series don 11,276 #2 Posted April 29, 2016 Hmmm.... Is the flywheel all the way in on the crankshaft? Share this post Link to post Share on other sites
pfrederi 19,810 #3 Posted April 29, 2016 On 4/26/2016 at 7:48 PM, howell1000 said: I have a sk 486 with kohler 16 horse put new stater and battery now it burns fuse and when i get it to work the bendix on starter will not go out far enough to turn over engine PLEASE HELP Thanks To be clear did you mean stator or starter here,...did you have the flywheel off?? Does it work properly if you run a heavy jumper from the battery + terminal directly to the Starter motor terminal (by passing the solenoid and all switches) Share this post Link to post Share on other sites
howell1000 35 #4 Posted April 29, 2016 Hi thanks for the info on the problem I was having just got it fixed yesterday Share this post Link to post Share on other sites
