Jp southwick 1 #1 Posted April 26, 2016 Jp southwickToday 8:48 PM I have a 1975 that all the sudden Fried an ignition switch and with that replaced I can not get any spark what else could have fried. It ran perfect prior to Share this post Link to post Share on other sites
c-series don 10,224 #2 Posted April 26, 2016 Do you have power to the positive side of the coil with the switch in the run position? 1 Share this post Link to post Share on other sites
Phatboy 565 #3 Posted April 26, 2016 And not to be capt obvious ,, bit did you check the fuse ? 1 Share this post Link to post Share on other sites
953 nut 60,718 #4 Posted April 26, 2016 If you tell us what model 1975 you have we can post the correct wiring diagram to help you figure it out. Share this post Link to post Share on other sites
Jp southwick 1 #5 Posted April 26, 2016 Where is the fuse located? Share this post Link to post Share on other sites
Jp southwick 1 #6 Posted April 26, 2016 it is a B-80 model I can't find a fuse where would it be located? my model doesn't have any lighting if that matters Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,561 #7 Posted April 26, 2016 There is a wring diagram in this manual Garry Share this post Link to post Share on other sites
pfrederi 18,773 #8 Posted April 26, 2016 There is no fuse. As mentioned are you getting 12 volts at the + coil terminal with the switch in run? If not make sure PTO is totally disengaged. Also check your new ignition switch...did it have an "I" terminal. (You may have been given wrong switch which has an "M" terminal for magneto ignitions) 1 Share this post Link to post Share on other sites
953 nut 60,718 #9 Posted April 26, 2016 Is your ignition coil the old style round ignition coil or is it the smaller sort of triangular type that is typical of magneto ignitions? The wire going to your ignition coil on the magneto type ignition will have no voltage on it at any time. It will be grounded when the ignition switch is off or when you are not in the seat with the PTO on. Like @pfrederi said, check the terminals on the new switch against the old switch, make sure they are the same. If you have a magneto ignition and have had 12 volts to it you may have harmed it. Share this post Link to post Share on other sites
