scotty 252 #1 Posted April 18, 2016 How do i adjust a one bottom plow? i can only get it to scrape the surface. Share this post Link to post Share on other sites
chorusguy 227 #2 Posted April 18, 2016 http://www.wheelhorseforum.com/topic/59093-need-help-with-plow-set-up/?do=findComment&comment=5 Share this post Link to post Share on other sites
Lagersolut 802 #3 Posted April 18, 2016 (edited) 9 hours ago, scotty said: How do i adjust a one bottom plow? i can only get it to scrape the surface. Check this thread with my pics - the top share adjustment needs to be turned almost to all the way in to plow . Make sure you have enough slack in your lift hardware when the plow is down for it go into the ground and plow . Edited April 18, 2016 by Lagersolut Add information 1 Share this post Link to post Share on other sites
Phatboy 566 #4 Posted April 18, 2016 (edited) Google brinly bottom plow set up,, or look on youtube,, because the width between your rear wheels make a difference on how you attach the clevise on the plow to your hitch ,, and what hole to use ,, then ya have to put both front and rear wheels on 6" blocks on the left side of tractor,, then adjust so the ground share ,, the long piece of angle iron sticking out the back is a inch off the ground at the back tip of it,, and the plow share(front of the plow that digs in) should be touching the ground,, ,, thats just a quick sumation ,,, but the important parts are there,,, Edited April 18, 2016 by Phatboy 2 Share this post Link to post Share on other sites
scotty 252 #5 Posted April 19, 2016 Ill have to try that thanks for the replies! 1 Share this post Link to post Share on other sites
Shynon 7,646 #6 Posted April 19, 2016 2 hours ago, Phatboy said: the long piece of angle iron sticking out the back is a inch off the ground at the back tip of it This is all I do on a flat level surface, it will give you a good starting point, may need to be adjusted for conditions. 1 Share this post Link to post Share on other sites
