Uk Nick
316 ( as US 416) with onan-oil light
Uk Nick
Hi
Have just got a 316-8 mowed the lawn and then ran out of petrol just as it was getting dusk .
Now it won't start.
What I have noticed that I did not before is that when you turn the ignition on the oil light comes on.
I have looked up the manual which says that on a 312 and 310 if the oil is low the engine won't start.
Is that the same with the 316-the manual shows that it has an oil  light but isn't specific about what its for( pressure or low oil)
My question is ,on a 316 is the oil light on when you turn the ignition on ,then goes off as the engine fires up and it gets oil pressure , or if the light is on when the ignition is turned on ,( and the engine is short of oil) the engine will turn over but not start ( as mine does).
The oil level is just above the minimum on mine at present.
Any help much appreciated.
Nick
woodchuckfarmer
Add some oil and see what happens. It just might start.
Edited by woodchuckfarmer
benji756
If it was running and ran out of gas ,then you added gas and it won't start check to see if you are getting gas to the carb. On my 520h the oil light comes on when I turn the key on then goes out when the motor starts.
doc724
If you run out of gas in one of these Onan's it does take more cranks than normal to get all the fuel lines and filter filled.  Choke it to increase the vacuum and crank-10-15 seconds of crank and then give the starter motor a little rest.  Repeat.  A couple of cycles of this and it will fire right up.
N3PUY
Disengage the PTO :techie-eureka:
  • Similar Content
    • lsc1257
      By lsc1257
      I have a 1996 520H Wheel Horse for sale.  The tractor has just over 800 hours on it.  It comes with a 48 inch deck.  The deck is a 1995 and has over 1,500 hours on it, as it came brand new with my 312-8 that I sold several years ago.  This 520-H has the swept front axle so it can handle a 60 inch deck.  I just replaced the battery and the deck belt this summer.  The engine is a 20HP Onan and it starts right up but requires the full choke.  The transmission is an Eaton 1100-062, hydrostatic.  The deck is in rough shape but the spindles appear to be in good working order.  The right rear tire has some cracking.  The original operator's manual for the 520H is included, as is the original operating and maintenance instructions for the deck, plus the installation instructions for the deck.  Also included is a new PTO belt and several miscellaneous deck wheels and rollers.  Additional pictures available upon request.  Asking $500.
    • 850ford
      By 850ford
      I am looking for a replacement Kohler for a 1980 c165,it is cradle mounted.
      Will a standard mount Kohler work, if I remove the cradle?
       I am located in Massachusetts
        Thanks
    • BrianStasC-101
      By BrianStasC-101
    • Joe Warren
      By Joe Warren
      Onan model BF-MS2425A Engine for parts. This engine pulled from NOS Bolens QT16 tractor that sat for 40+ years. Engine has less than 25 hours on it. Engine currently stuck. Local pick up in  Easton  MA.  $49  or offer.
    • Joe Warren
      By Joe Warren
      Wheel Horse
      Service Tool Kit
      Onan Industrial Engines
      ON-420-0556
      Kit is missing oil filter tool, otherwise complete. Tools in excellent condition. Small crack in plastic case, bottom, middle.
      $129 plus shipping cost.
      Message me if you are interested in purchasing. Thank you. Joe
