Ohwheelhorse
Little help with my new horse
Ohwheelhorse
Just picked this one up last weekend. No model tag but I understand its common. SN# 31395 closest I can figure it's a 1963 33r . But would like to make sure. Has a 6 hp Tecumseh.
  • Like 5
Phatboy
Im sure one of our experts will be on to help shortly as i myself know less than nothing about the older horses,,, and slightly above nothing on the newer ones lol !!!
Pullstart
Nice little lawn ranger!
I see that your hood is splitting in the same spot as mine.  I'll have to bust out the welder one of these days and finally break down to doing sheet metal work.
Ohwheelhorse
Yes I know I cringed when I seen it when I bought it. But it seems to be common. My 66 lawn ranger someone had already did a little on it. I can weld pretty well I was not to scared of it. Be a good excuse to brush up on my tig skills.
Pullstart
Yeah, I have limited access to tig, and I've done plenty of tool steel and stainless welding with the tig, but I just don't want to warp my old iron.  I suppose leaving it is no good either, eh?
Terry M
Nice little lawn Ranger you have!!  All the 62 Models I've seen start with a 62-XXXX..
So That would make yours a 63 model.   The 64 Models came with a different hood along with an engine mounted gas tank.
gwest_ca
Sure looks like a 1963 serial number but with electric start it would be a 33E. Recoil start is 33R
Garry
Tankman
TIG should do an excellent job! Save that Horse!  :handgestures-thumbupright:
Thanks in advance for helpin' that Stallion. He still has a lot of life left in him.
ol550
Nice Ranger.  Other than the hood cracks every thing else should buff out.
  • Similar Content
    • ebinmaine
      By ebinmaine
      I got this from a co-worker the other day.
      It's been in this form and in his possession for (25 - 30?) years, so he thinks.
      It appears to possibly be home-made from an implement type alternator from an old Sears GT.
      It hasn't run for at least 4 or 5 years until today. I tossed a bit of gas in it and it Wants to run. It does run with the choke mostly closed.
      It'll need to be cleaned out and likely will be fine.
      Can someone help me ID the engine??
      It looks like it was originally Copper colored.
      I need to order parts for a carb rebuild.
      I took a few pics all the way around and would be glad to get a specific spot.
      I could not find any numbers but also don't know where to look.
      Look at the "muffler". I have no idea what that is but it sure does NOT muffle anything !
      Also, Why the big housing and huge drive pulley attached to the engine instead of just 1:1 drive?
      The alternator is rated at 3600 RPM. Shouldn't the engine be more than able to do that?
