fireman 1,022 #1 Posted April 8, 2016 Posted this in the "What's in your mirror" thread but figured I start a new thread about it here. I happened upon this on Craigslist about 20 minutes after the seller listed it. I called and purchased it immediately. Lets just say it's probably the cheapest I've ever paid for a Wheel Horse tractor. Today I degreased and pressure washed it so I can roll it inside and get it running. The fender pan and hood need some straightening out but that's no big deal. Gonna go through it, change the oil, plugs, fuel filter, hydro filter/oil and see what happens. The hour meter shows 929 hours. 17 Share this post Link to post Share on other sites
Wheelin'theSky 57 #2 Posted April 8, 2016 When the phone starts ringing 20 minutes after they post a Craigslist ad, they usually realize they could have got a bit more for it. Nice find and good luck with it. I'd check the brakes too. With those dents in the hood it looks like the prior owner may have had trouble stopping it 5 Share this post Link to post Share on other sites
Ed Kennell 42,015 #3 Posted April 8, 2016 (edited) Looks great. A little hammer and dollie work and she'll look new. PO might have been DUI to put those wrinkles in her, but may be that's what made her a really nice find for you. And a great looking 60"er. Edited April 8, 2016 by Ed Kennell 2 Share this post Link to post Share on other sites
Amcwheel85 2,059 #4 Posted April 8, 2016 Great score! those hubcaps are expensive items! Share this post Link to post Share on other sites
roadapples 6,983 #5 Posted April 8, 2016 Seat looks near perfect also, good score.. Share this post Link to post Share on other sites
WNYPCRepair 1,923 #6 Posted April 8, 2016 Amazing how many of these I see with the left rear tail light broken, LOL Share this post Link to post Share on other sites
new horse 44 #7 Posted April 8, 2016 nice tractor!! Share this post Link to post Share on other sites
Gadget 37 #8 Posted April 8, 2016 Very nice! A deal like that doesn't pop up every day! Just curious... did you get it from the estate of George Jones? Share this post Link to post Share on other sites
KC9KAS 4,744 #9 Posted April 8, 2016 @fireman Nice looking tractor. What do you use to "degrease" before pressure washing? Share this post Link to post Share on other sites
stevebo-(Moderator) 8,532 #10 Posted April 8, 2016 When I want to remove difficult built up grease etc. I use Purple Power found at Walmart. You need to be careful when applying directly to paint and plastic as it can stain. Simple green is a little more mild and works very well. For final cleaning I usually use westly's white wall cleaner. Having a pressure washer and using it along with the cleaners is the best way to clean tractors. Share this post Link to post Share on other sites
russellmc301 600 #11 Posted April 8, 2016 my a-100 looked like someone was a bad driver the fenders where smashed and the headlights were both out. but we all know sometimes they act up Share this post Link to post Share on other sites
Ken B 3,189 #12 Posted April 8, 2016 Nice score Jeff. Hopefully with a little work she fires right up. Just think, now you don't have to wait on Stevebo for that pull off of his 520 versus your 318 Deere. 1 Share this post Link to post Share on other sites
fireman 1,022 #13 Posted April 8, 2016 I use straight simple green and let it sit for 15 minutes or so. Then use the power washer with a 40 degree tip taking care around certain areas. George Jones? Not sure. Your right Ken. Now just need to find a nice dirt lot to have the pull off! 1 Share this post Link to post Share on other sites
bizzo15 52 #14 Posted April 8, 2016 13 hours ago, fireman said: Posted this in the "What's in your mirror" thread but figured I start a new thread about it here. I happened upon this on Craigslist about 20 minutes after the seller listed it. I called and purchased it immediately. Lets just say it's probably the cheapest I've ever paid for a Wheel Horse tractor. Today I degreased and pressure washed it so I can roll it inside and get it running. The fender pan and hood need some straightening out but that's no big deal. Gonna go through it, change the oil, plugs, fuel filter, hydro filter/oil and see what happens. The hour meter shows 929 hours. Nice find! I'm very interested in how you're going to straighten that hood out, I've got similar damage from something heavy falling on my 312-8 while it was in storage and I haven't the slightest clue how to go about straightening it out. Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #15 Posted April 8, 2016 13 hours ago, WNYPCRepair said: Amazing how many of these I see with the left rear tail light broken, LOL I know what ya mean or is the right side... , Jeff 2 Share this post Link to post Share on other sites
fireman 1,022 #16 Posted April 8, 2016 Hammer, dollie, and so different size steel bars will take take most of the dents out. 3 Share this post Link to post Share on other sites
fireman 1,022 #17 Posted April 10, 2016 Well the weather was some what cooperative today so I headed out to see if I can get it fired up. Checked the oil and fuel tank. Oil was fine and fuel tank was empty which is a bonus (no stale gas)! I added fuel stabilizer and some fresh gas. Battery is shot (.5 volts and my charger read "Bad Battery") so I hooked up a jumper pack. The engine cranked and I saw fuel make it's way up to the fuel filter, but no fire. I sprayed the carb with some starting fluid and and cranked again and still nothing. I checked for spark and there was none. I can see that someone has monkeyed with the wiring a bit so instead of screwing around I went to the magical "Wheel Horse Demystification Guide" and printed out the section for the 1990 520H. Sometime this week I will go throw the wiring point to point and straighten out what ever the other guy messed with. In the mean time tomorrow I will pull off the hood and seat pan and get those hammered out. 2 Share this post Link to post Share on other sites
DougC 2,643 #18 Posted April 10, 2016 Nice find and a cheap price, wow! Better buy a lottery ticket now too......... Share this post Link to post Share on other sites
squonk 43,842 #19 Posted April 10, 2016 On 4/8/2016 at 7:04 AM, fireman said: Your right Ken. Now just need to find a nice dirt lot to have the pull off! Dirt? All you guys are gonna do is dig to China! Get on some nice sticky pavement. We want smoke, the twisting of frames and some grunting! Oh we'd like to see pics of the tractor's too! 4 Share this post Link to post Share on other sites
cheesegrader 433 #20 Posted April 10, 2016 (edited) I recognize that wiring! The PO has jumped a burnt connection at the 9-pin to get power to the starter. (and what an ugly splice! Yuck!) You are also missing a fuse (30 amp, I think) Edited April 10, 2016 by cheesegrader Share this post Link to post Share on other sites
Bow_Extreme 550 #21 Posted April 10, 2016 Here you go Fireman. I know the 520H wiring very well. I've probably redone 15 of them in the last 10 years. Share this post Link to post Share on other sites
fireman 1,022 #22 Posted April 10, 2016 48 minutes ago, Bow_Extreme said: Here you go Fireman. I know the 520H wiring very well. I've probably redone 15 of them in the last 10 years. Thanks for the tip! Share this post Link to post Share on other sites
Bow_Extreme 550 #23 Posted April 10, 2016 One more question. Did they really take a piece of extension cord and patch into the wiring harness? Share this post Link to post Share on other sites
roadapples 6,983 #24 Posted April 11, 2016 50 minutes ago, Bow_Extreme said: One more question. Did they really take a piece of extension cord and patch into the wiring harness? What`s your point ?.... 1 Share this post Link to post Share on other sites
fireman 1,022 #25 Posted April 11, 2016 (edited) Yup they sure did! Redneck engineering at it's best. They also used masking tape instead of electrical tape which I never use either. Shrink tubing is the only way to go to properly seal the connection and have a professional look. They funny part is shrink tubing is actually cheaper then a good roll of electrical tape! Edited April 11, 2016 by fireman 1 Share this post Link to post Share on other sites
