TDF5G 2,073 #1 Posted April 5, 2016 (edited) I took the dozer blade off of the B-80 and did some maintenance to get ready for mowing. I move blades and mower decks around the basement with the two wheeler dolly all the time. I wanted to put this one out of my way in the shed, which is uphill. I strapped it on with a couple of bungies and towed it with the . I'm lazy I reckon or maybe just wanted another excuse to use the tractor for something! Had to go easy or it would scoot over into the rear tire. The ball hitch mount was a PO install on one of my other tractors. It's two pieces of angle iron bolted on. Edited April 5, 2016 by TDF5G 14 Share this post Link to post Share on other sites
Pullstart 68,380 #2 Posted April 5, 2016 My old boss used to say "if you want to find an easy way to get a job done, hire a lazy guy"! 8 Share this post Link to post Share on other sites
Pollack Pete 2,273 #3 Posted April 5, 2016 Looks like you work smarter......not harder. 10 Share this post Link to post Share on other sites
953 nut 62,498 #4 Posted April 5, 2016 I have a piece of 2" X 1/4" flat stock welded to the top of my two wheel dolly which made it a trailer, works great. 5 Share this post Link to post Share on other sites
TDF5G 2,073 #5 Posted April 5, 2016 8 minutes ago, 953 nut said: I have a piece of 2" X 1/4" flat stock welded to the top of my two wheel dolly which made it a trailer, works great. I did put the blade in the dump cart one time and hauled it. Never tried that again. 1 Share this post Link to post Share on other sites
Aldon 4,828 #6 Posted April 5, 2016 I'm with Pete. Work Smart, Not Hard. Take it from those of us who now know that we should have saved our backs along the way. They are a lot like a tank of gas. Only so many hard miles you can put on them. 10 Share this post Link to post Share on other sites
Ed Kennell 43,264 #7 Posted April 5, 2016 Oh Man, at first glance, I thought we had the first rear mounted snow / dozer blade. 5 Share this post Link to post Share on other sites
oliver2-44 11,011 #8 Posted April 5, 2016 Yeas ago I pulled my hand truck out of the shed and found the back rounded part of the handle with a hole worn in it???? Turns out one of my sons and friends had taken it and tied it behind my mower (similar to your plow carrier) to give each other rides ...(and the handle wore through dragging on the dirt and pavement. Later I learned this had turned into who could stay on over the most bumps etc. Boys will be boys! 6 Share this post Link to post Share on other sites
DougC 2,643 #9 Posted April 5, 2016 I drilled the hole out in my hitch large enough so a hitch ball would fit a few years ago so I could tow my wood splitter to my timber or wood pile. Then remove the ball and use the hitch for my dump cart, lawn roller and lawn sweeper. 3 Share this post Link to post Share on other sites
TDF5G 2,073 #10 Posted April 5, 2016 30 minutes ago, oliver2-44 said: Yeas ago I pulled my hand truck out of the shed and found the back rounded part of the handle with a hole worn in it???? Turns out one of my sons and friends had taken it and tied it behind my mower (similar to your plow carrier) to give each other rides ...(and the handle wore through dragging on the dirt and pavement. Later I learned this had turned into who could stay on over the most bumps etc. Boys will be boys! That's sounds like something we would have done when we were kids! 3 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,362 #11 Posted April 5, 2016 2 wheel cart and a tractor is a lot smarter that 2 wheel cart and " call 911 " something popped in my back. 6 Share this post Link to post Share on other sites
AMC RULES 37,237 #12 Posted April 5, 2016 Perfectly acceptable, any excuse at all... just to use your . Works for me. 7 Share this post Link to post Share on other sites
ericj 1,579 #13 Posted April 5, 2016 now call me dumb or something nut if i wanted the blade up at the shed i would have drove the tractor up with the plow mounted and removed it there eric j 6 Share this post Link to post Share on other sites
KC9KAS 4,744 #14 Posted April 5, 2016 You aren't lazy, you are a thinker! "Work smarter, not harder"! 1 Share this post Link to post Share on other sites
SylvanLakeWH 29,442 #15 Posted April 6, 2016 I noticed the color of the cart also appears to be the acceptable color WH Red... 1 Share this post Link to post Share on other sites
Retired Wrencher 6,096 #16 Posted April 6, 2016 TDF5G Any time you can have an excuse to get some seat time it is ok. I have to get the 65 Springfield from under the porch. So I will be doing the same thing soon. It is all good. 1 Share this post Link to post Share on other sites
TDF5G 2,073 #17 Posted April 6, 2016 16 hours ago, ericj said: now call me dumb or something nut if i wanted the blade up at the shed i would have drove the tractor up with the plow mounted and removed it there eric j That's what I usually do Eric. It depends on the weather and what I'm doing at the moment with the tractors. This is an old extra blade I just got last fall and already had it off of the tractor in the garage before I realized what I was doing actually. It is easier to remove and install the blade or decks on the pavement in the drive or garage than on the hill in the back yard too! 1 Share this post Link to post Share on other sites
ronhatch 407 #18 Posted April 6, 2016 I prefer to change my attachments in my garage or the blacktop drive, depending on the weather. I like to separate the WH snow blade from the undercarriage because it's lighter to handle and easier to store in my tool shed I wish I had a cement floor rather then gravel in my shed. Share this post Link to post Share on other sites
BESTDOGEVER 218 #19 Posted April 6, 2016 I had a solid hitch (1x1)fabricated to fit my 310-8 so I could tow splitter and empty trailer and heavy loaded cart without bending stock hitch 1 Share this post Link to post Share on other sites
cleat 7,734 #20 Posted April 6, 2016 On 4/5/2016 at 0:25 PM, TDF5G said: I took the dozer blade off of the B-80 and did some maintenance to get ready for mowing. I move blades and mower decks around the basement with the two wheeler dolly all the time. I wanted to put this one out of my way in the shed, which is uphill. I strapped it on with a couple of bungies and towed it with the . I'm lazy I reckon or maybe just wanted another excuse to use the tractor for something! Had to go easy or it would scoot over into the rear tire. The ball hitch mount was a PO install on one of my other tractors. It's two pieces of angle iron bolted on. What is that beast parked behind the Wheel Horse blade ? Share this post Link to post Share on other sites
TDF5G 2,073 #21 Posted April 6, 2016 EZ-GO golf cart. Share this post Link to post Share on other sites
cleat 7,734 #22 Posted April 6, 2016 And it has a 2" receiver hitch. That could come in handy at times. 1 Share this post Link to post Share on other sites
TDF5G 2,073 #23 Posted April 6, 2016 I put that on there. It's a bumper hitch add on for a pickup truck from Harbor Freight. I do use it occasionally. Share this post Link to post Share on other sites
