JAinVA 4,638 #1 Posted April 1, 2016 I have several WHs that are in need of a cosmetic refresh.I know that many of you have redone the paint on your horses.The biggest problem I have run across is removing the decals on the hood and fender pan.I would welcome any tricks you guys have found to make this task easier.Thanks in advance.JAinVA JimAnderson Gloucester,VA 1 Share this post Link to post Share on other sites
slammer302 2,157 #2 Posted April 1, 2016 Using a hair dyer or heat gun with a straight razor blade works good 5 Share this post Link to post Share on other sites
953 nut 68,872 #3 Posted April 1, 2016 Klean-strip decal and Adhesive remover will get all of the goo and the decal off, any good auto parts store should have it. 4 Share this post Link to post Share on other sites
squonk 47,999 #4 Posted April 1, 2016 Rubber wheel pinstripe remover. 2 Share this post Link to post Share on other sites
857 horse 2,588 #5 Posted April 2, 2016 I dont have any pin stripes on my Rubber wheels..=).....But i use googone to get it started THEN a haiirdryer.........and googone to help with the remainiing 2 Share this post Link to post Share on other sites
DennisThornton 4,773 #6 Posted April 2, 2016 I usually used heat gun judiciously to soften and weaken the adhesive and just pull it off a few heated inches at a time. Too little heat and the decal won't release or just breaks as you pull too hard but too hot and the decal stretches too much. Focus the heat on the metal and remaining decal and none on what you are pulling on. Adhesive remover for what remains. 6 Share this post Link to post Share on other sites
can whlvr 994 #7 Posted April 2, 2016 oven cleaner works too Share this post Link to post Share on other sites
JAinVA 4,638 #8 Posted April 2, 2016 (edited) can whlvr Of the the responses so far your's is the only one that I am unclear about.Thanks by the way.Do you recomend spraying oven cleaner on the decal or as a treatment after scraping the decal off?Again thanks,can you elaborate? Edited April 2, 2016 by JAinVA Share this post Link to post Share on other sites
KC9KAS 4,746 #9 Posted April 2, 2016 Oven cleaner is a very caustic product, so be careful with it and use rubber gloves! Spray it on, let it set and it will soften the decal & adhesive for easier removal. 2 Share this post Link to post Share on other sites
varosd 1,185 #10 Posted April 2, 2016 my 2 cents is the hair dryer/heat gun on the opposite side of where the decal is attached. I find that the adhesive will warm up and as you then begin to remove the decal, it will "let" go. 5 Share this post Link to post Share on other sites
953 nut 68,872 #11 Posted April 2, 2016 If you plan to take it down to bare metal and are not concerned about the existing paint then have at it with whatever! If you are planning to remove the decal and freshen up the look then keep in mind that a heat gun can loosen the paint too and oven cleaner and other products not intended for decal removal will leave residue which will cause paint failure. Use an automotive product that was intended for the job at hand. 2 Share this post Link to post Share on other sites
can whlvr 994 #12 Posted April 2, 2016 yes kc9kcs is correct,be careful if you go this route,but ive used it in a pinch when I didn't have any other products at hand,if your stripping to bare metal I just grind it off with the flapper disk Share this post Link to post Share on other sites
rjg854 13,331 #13 Posted April 2, 2016 being the kind of savage that I am, I've used my propane torch to warm up the decal before removing 3 Share this post Link to post Share on other sites
Martin 2,134 #14 Posted April 2, 2016 As was mentioned above by Don @varosd, heat gun on opposite side is the easiest and quickest way..... no chemicals. I`ve never needed anything but the heat gun method..... 2 Share this post Link to post Share on other sites
Racinbob 13,122 #15 Posted April 2, 2016 (edited) Use oven cleaner and you WILL be repainting. Anything you use to attack the adhesive could attack the paint as well. Like others here I've found that only a heat gun is needed. I simple got the decal started and then aimed the heat towards where the decal still met the sheet metal. A steady pull on the decal and it will release itself leaving little, if any, residue. A quick wipe with a solvent and you're good to go. I always used my wifes hair dryer but just this week I picked up a heat gun at Harbor Freight for $8.99. Edited April 2, 2016 by Racinbob 1 Share this post Link to post Share on other sites
squonk 47,999 #16 Posted April 2, 2016 If you use one of these wheels on a drill the decal will come right off with out marring the paint at all. Acts like a big eraser Randy. Living along 89 makes anyone a savage! 1 Share this post Link to post Share on other sites
stevasaurus 23,816 #17 Posted April 2, 2016 Don and Martin hit the nail on the head. Heat from the back on the metal is the best way. 1 Share this post Link to post Share on other sites
JAinVA 4,638 #18 Posted April 2, 2016 I would like to thank each and everyone who responded.I think I will try all of the suggested methods.Some of the hoods need some body work and are rusty so they get stripped in the E-tank.Some just need the decals removed.Nice to know I have options.I knew you guys would have the answers.Thanks,again.JAinVA JimAnderson Gloucester,Va Share this post Link to post Share on other sites
Digger 66 3,530 #19 Posted April 2, 2016 This is done on HDPE but the principle is the same Share this post Link to post Share on other sites
Racinbob 13,122 #20 Posted April 2, 2016 (edited) I never go behind the metal mainly because you usually can't on vehicles unless you want to tear them apart. I also don't like getting the metal that hot when all you need to do is release the adhesive but obviously it doesn't hurt anything. Once you get the edge started it will pull right off cleanly following the the glue contact edge with the gun. I hadn't heard of the wheel Mike mentioned. This video covers that as well. Pretty cool and this guy likes it better than heat. Edited April 2, 2016 by Racinbob Share this post Link to post Share on other sites
doc724 927 #21 Posted April 2, 2016 I am glad someone asked this question because I was wondering the same thing. BTW, Goof Off is acetone based and it will remove paint. Goo Gone is citrus based and it will not remove paint, but then again it does not, in my opinion, do a very good/fast job at removing adhesives. It looks like heat is the preferred solution. 1 Share this post Link to post Share on other sites
Zeek 2,299 #22 Posted April 5, 2016 On 4/2/2016 at 8:37 PM, DennisThornton said: I usually used heat gun judiciously to soften and weaken the adhesive and just pull it off a few heated inches at a time. Too little heat and the decal won't release or just breaks as you pull too hard but too hot and the decal stretches too much. Focus the heat on the metal and remaining decal and none on what you are pulling on. Adhesive remover for what remains. I usually do this with good success. However I'm curious about Squonk's idea . . . On 4/2/2016 at 11:07 AM, squonk said: If you use one of these wheels on a drill the decal will come right off with out marring the paint at all. Acts like a big eraser Randy. Living along 89 makes anyone a savage! I might try this, where did you get it and long does it hold up on some of the really old decals? Share this post Link to post Share on other sites
squonk 47,999 #23 Posted April 5, 2016 I got mine from Napa. It depends on what the decal is made of and what kind of adhesive was used. I'm sure it won't work on everything, but it wont harm the paint. I did an old decal and the decal kind of disintegrated. I did have to use some chemical on the old glue. They last quite a while. Too much pressure and it will wear faster along with heating up the metal too much Share this post Link to post Share on other sites
