seven 202 #1 Posted March 21, 2016 Picked up at suburban finally!! (350)found one nearby it's all taken apart cause the guy was going too restore but he decided to sell it instead. Says everything is there I was wondering if someone could help me find a parts diagram for it , even the tranny is all apart .cause he said it needed new seals. 11 Share this post Link to post Share on other sites
ol550 863 #2 Posted March 21, 2016 (edited) It's like most puzzles but you need to start from the middle and work your way out. Check the manuals section for your diagram. Edited March 21, 2016 by ol550 2 Share this post Link to post Share on other sites
slammer302 2,157 #3 Posted March 21, 2016 I traded for a RJ awhile back that came in pieces good luck they are pretty simple machines Share this post Link to post Share on other sites
Racinbob 13,040 #4 Posted March 21, 2016 This will help you out. You don't need to open the transmission to replace the seals but it sure doesn't hurt to inspect everything. Don't forget pictures when you get started. 1 Share this post Link to post Share on other sites
oliver2-44 11,624 #5 Posted March 21, 2016 That seems to be my kind of tractor PARTS & Pieces! Rims & hood look to be in good shape, good luck with the rebuild 1 Share this post Link to post Share on other sites
Tankman 3,528 #6 Posted March 21, 2016 Easier to prep 'n paint! Don't forget to use Never-Seez on all that hardware. Share this post Link to post Share on other sites
RedRanger 1,470 #7 Posted March 21, 2016 Do I see a snow blade as well? Share this post Link to post Share on other sites
stevasaurus 23,742 #8 Posted March 21, 2016 ACE is the place with the Friendly 3 piece trans....................parts 1 Share this post Link to post Share on other sites
TDF5G 2,074 #9 Posted March 21, 2016 That looks like the best puzzle money can buy! You need to buy a completed one to see where everything goes! Share this post Link to post Share on other sites
seven 202 #10 Posted March 21, 2016 Ya I will say a few hail Mary's and go for it yes it's got a snow blade hopefully all the pieces are there .starting with transmission first. The engine turns over and has compression. Probably do valve job and new piston an rings also then if all is there paint or possibly powder coat 3 Share this post Link to post Share on other sites
AMC RULES 37,259 #11 Posted March 21, 2016 From what I can see... looks like a good lookin' you've scored there. Share this post Link to post Share on other sites
seven 202 #12 Posted March 24, 2016 Does someone know how to check the oil in the transmission. I didn't see a drain plug either? I replaced seals and two bearings other than that it all looked pretty good. 1 Share this post Link to post Share on other sites
Racinbob 13,040 #13 Posted March 24, 2016 You have to drain the tranny oil by removing one of the lower side plate bolts. Use 1 1/2 quarts or fill until it comes out the plug on the right side. Either way is fine. 1 Share this post Link to post Share on other sites
wallfish 20,219 #14 Posted March 24, 2016 There should be a plug on the right side, looking from back of the trans. Full when oil flows out Easiest to drain by removing one of the bolts holding the side plate to the cast center. Share this post Link to post Share on other sites
seven 202 #15 Posted March 27, 2016 What's the deal with putting duals on a tractor like this . was that ever a factory option or just something people started doing on there own Share this post Link to post Share on other sites
seven 202 #17 Posted March 27, 2016 Tranny is. Going back together fine just need to replace the two axle seals is there a number on these somewhere .the ones that were on it are missing Share this post Link to post Share on other sites
Racinbob 13,040 #18 Posted March 27, 2016 Here ya go: http://www.partstree.com/parts/toro/parts/83-2840/ You may be able to get them from Toro as well. Pricey buggers huh? 1 Share this post Link to post Share on other sites
Phil854 130 #19 Posted March 27, 2016 wow nice project. One mans loss is your gain! Share this post Link to post Share on other sites
seven 202 #20 Posted March 27, 2016 Ya but at least the brass bushings are good thxs Share this post Link to post Share on other sites
kthack657 335 #21 Posted March 28, 2016 If you need any specific pics let me know I have a 401 that is together and pretty oiginal...just know that right now it is green (was a golf course tractor) Share this post Link to post Share on other sites
oliver2-44 11,624 #22 Posted March 28, 2016 @kthack657 could you post some measurements of the suburban 401 drive belt idler spring. From the forum i've gleamed it's 4-1/2 long overall and 5/8 dia,..does that match yours ? also what is the spring coil length and the spring wire diameter. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,346 #23 Posted March 28, 2016 From my notes and don't recall which one the measurements came from 83-2730 Replaces 1014 1014P 1486 Possibly replaced by 108035 but 83-2730 and 108035 both still available from Toro. Makes me think there is a difference somewhere. 4.500" between hooks .070" wire .520" coil OD .380" coil ID 3.570" coil length 52 + two 1/2 coils Garry Share this post Link to post Share on other sites
seven 202 #24 Posted March 28, 2016 When I get home later I can dig thru some boxs of parts and see if I can find it? Share this post Link to post Share on other sites
AlwaysLookin80 1,308 #25 Posted March 29, 2016 (edited) Pm me and I'll give you my number if you need help. I just did a full frame off, every nut and bolt is new on my suburban. I can tell you where everything goes and I even took pictures on my phone as I reassembled it. Edited March 29, 2016 by J.A. 1 Share this post Link to post Share on other sites
