Similar Content
By 2003Chevy
Hello All!
Added THREE tractors all at once yesterday(09/16/2025). Two model 854, and one model 855. The two 854 look pretty nice, but are not running right this minute --does not look like much more than a little tinkering/refreshing after sitting for a long time. The 855 was labelled a "parts" tractor, but except for it being Really well-used looking, it seems to be all there so I am not going to consider it out of play yet. The two 854's have rear discharge mower decks...one is a square style deck, the other the rounded style deck.
I think it is really nice that all three are basically the same machine, separated by one year, yet completely different styles--the end of one era and the beginning of another I guess.
There is an ID tag on the 855 (serial number 135166) but on the two 854 tractors, there is No tag under the steering like late models. Are the tags in a different place on older machines? Looking them over, I do not notice anything obvious. The 854 with the lower Kohler engine serial number has the round style mover deck, while the one with the slightly higher engine serial number has the square style deck.
All for now! Be well and stay safe.
[rayg]
By WH1618speed
1965 Wheel Horse 855 with 42" blade and chains
Runs good
Sheet metal is very straight, great candidate for restoration.
Missing Belt guard
Will sell tractor by itself for $500 without blade and chains
Blade is straight and lots of cutting edge left... just a little rusty.
Text, call, or email with any questions. If you call and I don't answer please leave a voicemail with your name and number. Thanks!
I can also deliver to the big show in Arendtsville, PA... IF you prepay.
Facebook Marketplace link with more pics: https://www.facebook.com/marketplace/item/598023068755689?rid=229092436403311&ad_id&rt=1&refID=0&refType=0&referral_code=commerce_attachment
By KC9KAS
My 875 is missing the small spring that is attached to the cam/neutral plate.
The part number is 1230 and NLA.
Anyone have one or know the dimensions of the spring?
Thank you!
By admin-(Admin)
1 page 196.25KB
1 page 82.24KB
Dated February 17, 1965
232613 Kohler belt nla Use 231605
232613 - Gates 7320 .41"x32.58" 36 degree or Napa 25-7320 .41"x32.58" 36 degree
231605 - Gates 7315 .41"x32.08" 36 degree or Napa 25-7315 .41"x32.08" 36 degree
1964 model 854
1965 model 855
1965 model 875
Starter/generator belt
Kohler 10hp, 12hp - 235262 (7345 Gates .410" x 35.09" 36 degree) (25-7345 Napa .410" x 35.09" 36 degree)
Wheel Horse 1593 (3L x 34.4") - nla (Gates replacement 6735 3/8" x 35" 38 degree)
1964 model 1045
1964 model 1054 - Not in PSB - Wheel Horse # 1593 nla {3Lx34.4"} - Gates 7340 .410"x34.58" 36 degree or Napa 25-7340 .410"x34.58" 36 degree
1965 model 1054A - Not in PSB - Kohler 235262 replaces 235528 [.41"x35.09" 36 degree] - Gates 7345 .41"x35.09" 36 degree or Napa 25-7345 .41"x35.09" 36 degree
1965 model 1055
1965 model 1075
By DownHome
Looking for belt specs for my 855. Need to know which belt I need to attach from motor pulley to mower 36" mower deck. Thx
