Phatboy
Eaton 1100 transmission..
Phatboy
Ok guys so im teaching myself about my new 520H and went to eatons site and read the manual , then read wheel Horses manual and they Both call for either 10W-30W or 10W-40W,,, in the transmission so here is my question,, i see alot of guys here saying they use straight 30W,, so that being said i have recently read alot of folks using Rotella oil , i was wondering if i could use Rotella 15W-40W,,, this way it thickens up the minimum viscosity but keeps the recomended maximum viscosity.. Any thoughts ? I was also thinking of using the same in the engine...what do you guys think as i am a 520 noob lol,, bit am trying to do everything i can to keep my 520 running at its peak for as long as possible.. Thanks in advance for your replys..
Edited by Phatboy
cleat
I run straight 30W in the engine but 10W30 in the transmission.
Straight 30 would be too thick for the transmission and the lift would take a very long time to function if at all in cool weather.
squonk
I use Mobil 1 10W-30 in all my hydros
Phatboy
Do you use mobil 1 in the engine also ?
shallowwatersailor
Having had two 520-H, the Onan manual for the engine calls for straight 30W. I have had good luck with Rotella 30W in the gallon jug. It gets used in the Kohler -K-Series engines as well. The two 5xi with the Kohler Command engines get Amsoil 10W-30/30 synthetic.
Phatboy
Ok that is what i used , the Rotella T1 straight 30W,,,i also was looking for like a K&N oil filter that ppl were talking about here in the forums ,, but it was discontinued,, so they cross referanced it to a Mobil 1 , high performance filter,,  so i used that,, part # is ,, M1-102,, its a High efficiency,, High capacity , Extended Performance filter..
  • Similar Content
    • Duramax7man7
      By Duramax7man7
      Very Solid tractor!
      Newer Agro Tires on Rear and Solid Front Turf Tires. Wheel Weights on rear. Fully Swapped Forward Swept axle off of 520h. I ran my 60" Deck on this tractor for over a year with no issues.
      Deck it solid top to bottom with no rot and newer blades. Belt and Pulley are good to go!
      She's just a little dusty and needs a cleaning. Can get a nice Seat a Tractor Supply.
      $1175 OBO   -POOS
      (248) 9for3-8six3four Text or Call. I do not visit this site enough. God Bless.
      NEW SEAT INSTALLED ON THIS TRACTOR! Started it up and ran it for a while yesterday... Forgot how nice this thing is. Tempting to keep it but it's time to send her one her way. GREAT TRACTOR!
    • RJ Hamner
      By RJ Hamner
      Now that we are finding more uses for the 1990 520H with a KwikWay loader I am experiencing some power loss in the hydro after about a half hour to 45 minutes??????
      Ideas?
    • lodestonefarm
      By lodestonefarm
      Selling my trusty WH520H.  ~880 hours (currently used for moving snow when needed so hours may rise) very solid machine, strong and hardworking.  20HP Onan, hydro transmission and hydraulic lift.  Has Matt's foot-pedal conversion for forward/reverse.  Included in the sale is a tall-chute snow blower and 60" mowing deck.  The blower is in excellent condition and is on the tractor currently.  The mowing deck has been a workhorse over the years.  No holes but could use some TLC, probably needs new spindles at some point and could use a couple spots touched up with welder also does NOT have any pulley covers/protectors (see photo).  Tractor has been an incredible tool, very solid and dependable and I'm certainly going to miss her when she's gone.
      Recent maintenance: replaced the plugs this summer, fluids as needed (hydro has about 100 hours on fluid/filter; oil was done in the spring and has about 25 hours on it).  Battery is about 3 years old as are the tires, Terra Trac tires on the rear and turfs on the front.  The seat (with arm rests) isn't in great shape.  I've got a cover for the seat, never used.  It's never really bothered me but new seat cover is included in sale as are 4 hub caps, chains for the rear tires, and some misc spare parts (see photos).
      I've owed this machine about 8 year and put ~350 hours on her.  She's not a show piece but could be restored.  Sheet metal is generally in shape, no rust however the hood does have a couple dings in it.
      I'm only selling because I'm trying to help my son get a small lawn care business started and looking to move to a zero-turn.  The 60" deck is too large for our trailer, the mowing deck lacks pulley safety shields, and we'd like something that mows faster.  My only complaint with this machine is the top-speed (which isn't great when comparing to today's machines) otherwise she's a beast.  They don't make them like this anymore.
    • Workin_Horses
      By Workin_Horses
      Nice solid clean 60" deck for 520H Model # C560SC04       $500 OBO
    • RJ Hamner
      By RJ Hamner
      I have a new-to me 1990 520 with a KwikWay loader. Have been going thu piece by piece and checking for anything that needs attention. Found some wobble in the rear hubs (both sides) the key ways on both the axles and hubs shoe some pretty heavy wear.  Was wondering if you have used the hub repair kits that A-Z sells and any comments good or bad?
      Thanks
      Bob
