rwilson 128 #1 Posted December 9, 2008 I just picked up a tiller today. It fits a ford lgt165 with a rear pto. I think i can make it fit a wheel horse. It was free so I can do something with it!! I was thinking it would be easier to mount a motor on top of it and just run a belt down to a pulley on the shaft. Any sugestions on what kind of HP i would need? Or any other sugestions would be good. :hide: Share this post Link to post Share on other sites
Rollerman 291 #2 Posted December 10, 2008 There is a member here that built a tiller attachment for his D series with a 3 point. He used a pony engine on it....but the pics our no longer up. I would think 3 to 5 horsepower range would work depending on the width of your tiller? Share this post Link to post Share on other sites
rwilson 128 #3 Posted December 10, 2008 its 36 inches wide. I have a 5 hp and a 7 hp. the 7 needs rebuilt it smokes bad. and the 5 might be the way to go Share this post Link to post Share on other sites
bitten 134 #4 Posted December 10, 2008 Do you have a picture of it? It would help thr imagination. P.J. Share this post Link to post Share on other sites
Confused99 2 #5 Posted December 10, 2008 Would there be a possible issue putting a side load on the PTO input shaft? Just a thought? Share this post Link to post Share on other sites
catman81056 3 #6 Posted December 10, 2008 I made this one for my D160. Share this post Link to post Share on other sites
Rollerman 291 #7 Posted December 10, 2008 There is a member here that built a tiller attachment for his D series Tim should have mentioned your name... :hide: Share this post Link to post Share on other sites
linen beige 16 #8 Posted December 10, 2008 Sears has these for sale. Looks like 8.75 Horse power. http://www.sears.com/shc/s/p_10153_12605_0...s&sName=Tillers Check out the WT-30 in the gallery section. It was a thirty inch and used a Kohler K-91, 4 horse power. Also there were the twenty four inch WT-241 and WT-242 with Lauson 5.5 horse power and the WT-244 with Lauson 6 horse power. Share this post Link to post Share on other sites
Confused99 2 #9 Posted December 10, 2008 Sears has these for sale. Looks like 8.75 Horse power. http://www.sears.com/shc/s/p_10153_12605_0...s&sName=Tillers Those are pretty much junk. My neighbor had one and used it to till his whole yard up (1/3 acre) and when he was done, the thing was pretty much useless without some repair. He did end up taking all apart and replaing the bearings, bushings, etc and then sold it. I didn't have my tiller at the time or that would have been a fun comparison. Share this post Link to post Share on other sites
linen beige 16 #10 Posted December 10, 2008 Those are pretty much junk. What isn't these days? Merely posted to give you some ideas on fitting an engine/clutching arrangement. Using quality parts it should be fairly easy to fab something up. I have a 36 inch rear tiller myself that I've thought seriously about fitting with it's own engine. That way I could use it with several of my tractors without having to fool with all the different idler pulleys and belts. Share this post Link to post Share on other sites
Confused99 2 #11 Posted December 10, 2008 What isn't these days? Merely posted to give you some ideas on fitting an engine/clutching arrangement. Using quality parts it should be fairly easy to fab something up. I have a 36 inch rear tiller myself that I've thought seriously about fitting with it's own engine. That way I could use it with several of my tractors without having to fool with all the different idler pulleys and belts. Yeah, no kidding. I should have figured you were not promoting that item. I agree that a seperate engine on a WH tiller would be nice in some ways. Share this post Link to post Share on other sites
CasualObserver 3,417 #12 Posted December 10, 2008 I agree that a separate engine on a WH tiller would be nice in some ways. that's they way the started out. For some reason it was considered a technology advancement to run a long freaking belt thorough idlers and under the tractor. Seems a whole lot simpler to hitch up the WT-241/242/244 units to me. Put it in the slot hitch, place the pin, pull the rope and go. Doesn't get much simpler. these are in the implement gallery: WT-30 WT-242 WT-244 (my 244 has extensions on each side, it's just about a 32" cut) Share this post Link to post Share on other sites
catman81056 3 #13 Posted December 10, 2008 Well I'd sell my tiller in a second if I could get one that runs off the rear PTO on my "D". I have a few parts around at this time that are going to be my next tiller project, and it will run off the rear PTO. Anyone want to trade? :hide: Share this post Link to post Share on other sites
rwilson 128 #14 Posted December 11, 2008 if it wasnt so far away from me i would trade ya. What hp motor did you use and how wide is the tiller? Share this post Link to post Share on other sites
catman81056 3 #15 Posted December 11, 2008 The tiller is 45" outside the tines, the motor is a 4hp Briggs. I have a 6hp that I was going to put on it but hopefully I'll have the PTO driven tiller made by Spring. I bought the bigger motor after the tiller was built or it would have already been on it. If you go this route, I'd use no less than a 5hp, the 4hp tends to bawg when ran deep. Share this post Link to post Share on other sites
rwilson 128 #16 Posted December 13, 2008 Well if your 4 hp runs 45 inches then the 5 hp should run a 36. All i can do is try it. thanks for the info. Share this post Link to post Share on other sites
