dells68 7,499 #1 Posted February 16, 2016 Hey guys. I'm trying to remove the steering wheel on my GT14. I've got the shaft bolt out and soaked the shaft and keyway with PB Blaster. It'll wiggle, but won't pull up. Appears to be on a keyway, but there is a hole through the hub down on the shaft. Doesn't appear to be a rolled pin in there. If I use a puller, it will damage the wheel. Any suggestions on how to pull it? Going to need one of Glenn's dash panels, mine is broken. Share this post Link to post Share on other sites
953 nut 62,499 #2 Posted February 16, 2016 See if you can rent or borrow a device called a "Bearing Splitter from an auto parts house or rental center, put it under the steering wheel and pull on it. 2 Share this post Link to post Share on other sites
dells68 7,499 #3 Posted February 16, 2016 Thanks! I didn't even know there was such a thing. Learn something new everyday. That's why I like messing with stuff - only way to learn and gives you satisfaction when you accomplish something. Share this post Link to post Share on other sites
Aldon 4,828 #4 Posted February 16, 2016 HF sells a kit that has one in it. Depending on rental costs or if no one near you rents one, it might be worth considering.... Share this post Link to post Share on other sites
N3PUY 1,031 #5 Posted February 16, 2016 (edited) Here's how I got mine off ..... hoisted the whole tractor by the steering wheel and pounded the shaft out. Edited February 16, 2016 by N3PUY 2 Share this post Link to post Share on other sites
dells68 7,499 #6 Posted February 16, 2016 You wouldn't think it would be so tight! I've removed antique car wheels with less trouble 1 Share this post Link to post Share on other sites
dells68 7,499 #7 Posted February 16, 2016 Well, you've heard of a BFH? How about a BOS? That's a Big Ole Screwdriver. I took a flat blade screwdriver with about a 14" shaft and started prying around the wheel hub. Once it started to move, I used my BOS and a regular screwdriver to keep it working up. Cleaned the shaft and coated it with anti seize so I don't have to go through this again!!! Guess I lucked out this time 2 Share this post Link to post Share on other sites
cleat 7,734 #8 Posted February 16, 2016 I would think if it will wiggle, it should come off. Just keep soaking the penetrating oil to it. Share this post Link to post Share on other sites
MWR 321 #9 Posted February 16, 2016 13 hours ago, N3PUY said: Here's how I got mine off ..... hoisted the whole tractor by the steering wheel and pounded the shaft out. Looks like something I would do. 1 Share this post Link to post Share on other sites
