lodestonefarm
Current value of tall chute snow blower
lodestonefarm
22 minutes ago, WNYPCRepair said:
depends. Do you have pictures?
Well, I don't own it, but here are a couple pictures.  I can't really tell much from these regarding the overall condition.  I can send you a link if your interested.  I'm not sure I want to get caught in the middle of a three way exchange, but if you're really looking to move up to a blower for your 522, I know a guy who could use a good deal on a ready-to-go tall chute :)
WNYPCRepair
Auger is in good shape, and it is for an xi. Where are you in PA, and where is it?
The only one I have at the moment is the short chute I converted to a tall chute. I'll look for pics.
lodestonefarm
That unit is listed as Aurora, Ohio.
I was pretty desperate yesterday after spending a couple hours getting my 520 with plow, stuck and unstuck only to get it back to the shed before bringing out the big guns - New Holland TC45 with front end loader.  My drive is clear now and I can probably limp through the rest of winter so I'll probably watch carefully for a tall chute.  I'm only going to get one chance to buy a blower.  I'm already on thin ice claiming the Wheel Horse was necessary for plowing-  that works fine when we get less than about 8".  Monday night dropped about 14" and I just couldn't make any headway!
WNYPCRepair
If you can wait, they will be cheaper in spring, and probably more available.
lodestonefarm
Well I figured out the value of a snow blower to me.  $450.  I got a really nice tall chute blower on Thursday.  Many thanks to TheRoundHousernr for sending me a link for a very clean unit for sale near him.  Here are a few photos.  I got it mounted today, slowly working around a giant mud mess in my shed.  Some day I'm going to build a garage, but for now, I'm celebrating a new blower.  Of course it's 50-degrees today, but I know we'll get more snow some day and this baby is going to chuck it as far as I want!  :bow-blue:
Thanks everyone for the input and for steering me away from that other unit.  This unit is so clean there are only a couple places where the paint has worn off due to use.  The skid plates still have paint on the bottom!
I do have a couple questions but I'll start a new thread for specific questions about this blower.
Again, thanks to all the great input.
  • Like 7
varosd
Peter,
              That is a great looking tall chute!   I'm still in the hunt to swap out my short chute. lol
lodestonefarm
Thanks.  Believe it or not, I'm actually rooting for snow now!  - ducks to avoid flying objects-  Actually I'm hoping what we have melts off the drive way so I can walk it and get most of the stones back where they belong.  Pushing it around the last storm with the loader caused a lot of damage.
WNYPCRepair
That is a nice blower, and probably worth the price
DennisThornton
You and I need to stand together to defend our rights to properly equip ourselves to remove snowfalls!  Wheel Horses (multiple!) ARE needed even with "big guns"!
lodestonefarm
AGREED!  I'm hoping the blower does so well I get some brownie points which I would then attempt to turn into a smaller 300 series wheel horse.  I could mount the plow on that one and be ready for snow no matter what kind.  Aside from the difficulty of using the FEL, my old Yanmar isn't a good starter in the cold.  It was my father that came by with is larger tractor and did most of the work.  But on my long narrow drive a loader isn't very convenient.  A plot on that big tractor would do the trick.  I could probably do a pretty good job with a back-blade on my YM240, but that wouldn't solve the starting when cold problem....   So yes, we need to stand together.
DennisThornton
FELs are NOT the answer for snow, other than relocating piles of it.  However, I have a 7ft truck snow plow modified to fit on my FEL that angles and does VERY well with heavy snow but I have areas that aren't conducive to plowing and really need to be blown, except for very light snowfalls.  My road/driveway setup really demands multiple tools to tackle unpredictable snow storms.  I already have a back blade but I'd even like to add a mid-mount grader blade to my snow team.
JackC
"my old Yanmar isn't a good starter in the cold "  For a diesel engine compression ignites the fuel rather than spark plugs. There can be many reasons for hard starting in winter but good glow plugs to pre-heat the cylinders and proper valve adjustment is required for a diesel to develop maximum compression to ignite the fuel.
lodestonefarm
Yeah, that's part of the problem.  This model doesn't have glow plugs.  It has a thermostart which is supposed assist in cold-weather starting.  It also has a de-compression lever which allows the engine to roll over and distribute oil as well as gain some momentum, but when it's single digits, it's just not enough.  Fortunately, it also has a block heater which works great, but that requires it be parked near the house (and outside) rather than in the shed where there's no power.  It's always something....  That's what I like about the WH.  She starts right up no matter the temp!
JackC
Apparently the thermostat acts like a glow plug. Have you checked this out? Maybe time for a new thermostat? Google:
Inside A Yanmar Thermostart
Theroundhousernr
Hey! Glad you went and got it. Was wondering how you made out. I think one in that shape is worth 400-450 all day long and should serve you well. Find a good chain lube to spray on after every use and something slippery for the chute like snow jet.... You will be happy with it , I am sure. Also, I like to run my belt on the inside pulley. I usually only run the onan engine at around 3000 rpms and that puts the speed right around the same speed if you where on the outside pulley. Then if you need the extra speed on the auger to really show off lol you can rev it up to 3600.  Also that model should have greasable bearings which is nice to push moisture out of them and keep them lubricated. Good luck and post some pictures after the next storm.
MalMac
Nice blower, hooked to the 520 you should have ample power. One note though, looks like your side wing plates are on wrong. they should angle out then point straight forward to help cut through the snow. Just unbolt and flip around.
doc724
It is hard to see in the picture, but I believe that the side plates are on correctly.  Take a close look at the left plate in the top picture.  The final bend is pointing directly at you so it is very hard to tell-you need a pretty big screen monitor to see it.
lodestonefarm
Thanks.  Although I'm not certain how the wings should be, the leading edges of the wings are parallel to each other.  That makes sense to me.  I got the manual with the blower so I'll look there to see how it should be.
MalMac
I stand corrected, if you look hard you can kinda see it. But it is very hard to tell, good catch. I would have had him all kinds of confused.
JoeliusZ28
Looks great, i think you got a good deal. We havent had any snowfall here since i bought mine either so as far as im concerned its working perfect :lol:.  Not going to lie im excited to use it though.
i saw someone mention using the inner PTO pulley.  I tried this on my 414-8 because i figured the extra speed would be good, but it looks like the bottom idler isnt aligned with that and puts the belt at a little bit of an awkward angle. It works, but looks like its more of a risk of wear and popping off than with the outer pulley.  Any thoughts, is the 520 this way too?
lodestonefarm
I appreciate that link.  I've already been all through this with the Yanmar over on another site.  I think this thermo start is working correctly, as does the de-compression lever, but when it's zero degrees everything is hard starting.  When I really need the Yanmar, I just have to plan ahead and plug it in.  Thank goodness for the block heater.
No worries.  The photos I posted weren't all that great and when I look at them all I can see is mud!  I do appreciate all the input and suggestions.
lodestonefarm
This unit does have zerks for greasing.  How do you know when you WH is at 3000 rpm?  All my gauges work but none of them are a tach.
Theroundhousernr
What year is your 520H? Figure on a little over 3/4 throttle.
lodestonefarm
I think it's a '94 but I'll have to check.  I have a gauge that is something like 'load'.  It's a percentage not a true RPM.
Edited by lodestonefarm
posted to wrong thread
Theroundhousernr
All 520 tractors have a tach unless its an HC and even some of those had them. If yours is a 94 it has it. You have voltage, fuel, tach, hour meter, and the vaccum meter which would be the load meter you describe.
  • Similar Content
    • cyrus
      By cyrus
      1996 416-H Wheel Horse Garden Tractor
      Model # 73423
      1355 hours
      Features Electric Clutch Hydrostatic Drive Hydro Lift (mid & rear) Accessories 48" 3 blade mower deck Model #78360 Newer Blades 48" single stage High Chute Snowblower Model #79360 Side Wings for 60" cut sidth Newer Chain and Drum Sprocket 20lb Rear Wheel Horse Wheel Weights Rear Wheel Skid Chains Soft Side Snow Cab Rough but useable. Other info New Battery New Hydro Lift Cyl Hoses New Main Electrical Wire Harness Recent service (Engine Oil, Hydro Oil, Filters, and Chassis lube) Tires are in good shape with no leaks A bit cold blooded, but starts and runs great once warmed up uses no oil.
      located in Zeeland Michigan, purchased new from Westenbrook Mower in late 95. My parents are moving to a townhouse and have no further need for their trusty horse. I have my own, so off to new pastures for this one.
      Pick up only.
      8509515355704655080.mp4
    • lodestonefarm
      By lodestonefarm
      Selling my trusty WH520H.  ~880 hours (currently used for moving snow when needed so hours may rise) very solid machine, strong and hardworking.  20HP Onan, hydro transmission and hydraulic lift.  Has Matt's foot-pedal conversion for forward/reverse.  Included in the sale is a tall-chute snow blower and 60" mowing deck.  The blower is in excellent condition and is on the tractor currently.  The mowing deck has been a workhorse over the years.  No holes but could use some TLC, probably needs new spindles at some point and could use a couple spots touched up with welder also does NOT have any pulley covers/protectors (see photo).  Tractor has been an incredible tool, very solid and dependable and I'm certainly going to miss her when she's gone.
      Recent maintenance: replaced the plugs this summer, fluids as needed (hydro has about 100 hours on fluid/filter; oil was done in the spring and has about 25 hours on it).  Battery is about 3 years old as are the tires, Terra Trac tires on the rear and turfs on the front.  The seat (with arm rests) isn't in great shape.  I've got a cover for the seat, never used.  It's never really bothered me but new seat cover is included in sale as are 4 hub caps, chains for the rear tires, and some misc spare parts (see photos).
      I've owed this machine about 8 year and put ~350 hours on her.  She's not a show piece but could be restored.  Sheet metal is generally in shape, no rust however the hood does have a couple dings in it.
      I'm only selling because I'm trying to help my son get a small lawn care business started and looking to move to a zero-turn.  The 60" deck is too large for our trailer, the mowing deck lacks pulley safety shields, and we'd like something that mows faster.  My only complaint with this machine is the top-speed (which isn't great when comparing to today's machines) otherwise she's a beast.  They don't make them like this anymore.
    • Upnorthman
      By Upnorthman
      314-8 In great shape. Used for mowing more than anything. Bought it a few years ago but got a new tractor. I used the blower very little and it sounds like it needs a bearing on it. Runs well. I have new chains I've not put on yet and extra belts.
    • Trouty56
      By Trouty56
      Tractor vs. Implement cross reference chart for models from 1955 - 2000
      110 pages 513.43KB
      This chart lists the original attachment model
      The model that replaced the original model
      The model that was available when the list was made
      Often many models between the last two are not listed.
      You must go from year to year and follow the model numbers to see them all.
      For a complete list of models click on the magnifying glass in the Search box. Enter DNA in the Search box and select Files from the drop down menu. Two pages of 33 results will come up in random order. Find the attachment you are looking for and click on it. The DNA for that model of attachment will come up. Look for the model of your attachment in the DNA list. They are organized from earliest to latest.
      OR
      Search the Files using a model number you know will work. Look through the results for DNA in another file name for the same item. That will have the full list of models.
      STD for a model indicates that attachment was standard equipment that came on that model of tractor.
      Mistakes in the online attachment list @ Toro. The Attachment Interchange is correct but confusing and the source of the mistakes.
      1970 *VS           rear discharge mower deck                             5-7362 is correct replaced by 5-0610 both CCW rotation
      1971                  rear discharge mower deck                             5-0600 - CW spindle rotation fits long frame tractors only
      1971 *CG-7 & 8 rear discharge mower deck should be model 5-7362 - CCW spindle rotation
      1972 *CG-7 & 8 rear discharge mower deck should be model 5-0610 - CCW spindle rotation
      1973 *VS           rear discharge mower deck should be model 5-0611 - CCW spindle rotation
      1970 *VS          side discharge mower deck                             5-2365 is correct replaced by 5-0700 both CCW rotation
      1971                  side discharge mower deck                            5-0710 - CW spindle rotation fits long frame tractors only
      1971 *CG-7 & 8 side discharge mower deck should be model 5-0700 - CCW spindle rotation
      1972 *CG-7 & 8 side discharge mower deck should be model 5-0701 - CCW spindle rotation
      1973 *VS           side discharge mower deck should be model 5-0702 - CCW spindle rotation
      1974 Replacement rear discharge mower deck for the model 5-0622 (side discharge) is wrong - should be 65-36XR01
      *Models using a vertical engine crankshaft
    • DennisThornton
      By DennisThornton
      I had the notion that these weren't worth bothering with but the price was just too good for this much painted red sheetmetal!  The owner loved it but replaced it with a BIG tractor/snowblower and a Ferris 60".  He hated to see it go but had no room for it and wasn't going to leave it outside.  I just had too...
      Many of you will know what it is but not long ago I wouldn't have!
