ztnoo
Wheel Horse Blower????
ztnoo
Anyone have any info about this implement?
can whlvr
kinda looks like a grain pump,to load silos but I doubt that's one
elcamino/wheelhorse
There appears to be a tag on the housing, are there any numbers or words on that ?
ztnoo
There does appear to be a plate of some sort which might give a clue, but these were the only two pics in the ad listing I saw.
WHX??
Need to bring a pro in on this id..
@CasualObserver
WNYPCRepair
My guess is a vacuum for a bagger?
Pulley is on the left (in the picture), which says to me it goes on the rear, like a tiller, not the front or mid TachOMatic.
Edited by WNYPCRepair
C-101plowerpower
vac bagger blower that is
woodchuckfarmer
Ive got one and it works like a charm . It blows into a cage, covered with screen on my two wheel cart.
ztnoo
Pics and info about the tractor and the installation?
ztnoo
Got some specific info from the seller showing model and serial numbers.
I'm sure someone more knowledgeable than myself can probably identify this by year of manufacturer by these numbers.
56bb121364d3a_WHvacblower2.jpg.1f5a85730
gwest_ca
If the model number is 7-2611-8 it is a 1973 model (8-5=3=1973)
The serial number 945307 or 807?
Garry
  • Similar Content
    • Brooklyn581
      By Brooklyn581
      Rear mount leaf collection system blower. Trailer with Canvas avail for an additional $100.
      $200 for both or Would trade both for a snow thrower attachment that mounts to the older style long frame for a Wheel Horse Charger 12. Upstate NY Pick Up only.
      Excellent condition. Even the decals are original.
    • Mjhinno
      By Mjhinno
      Excellent condition Wheel Horse OEM blower and bagger system removed off my 520H because I don't mow my yard any longer. Includes all mounting brackets for bags and blower, along with double pulley and belt for deck. Bags are good and intact and show some fraying along top frame edge. No cracks in the bagger hood or deck to bag chute. Blower blades are straight, balanced and complete. Best to text or email me
    • lodestonefarm
      By lodestonefarm
      Selling my trusty WH520H.  ~880 hours (currently used for moving snow when needed so hours may rise) very solid machine, strong and hardworking.  20HP Onan, hydro transmission and hydraulic lift.  Has Matt's foot-pedal conversion for forward/reverse.  Included in the sale is a tall-chute snow blower and 60" mowing deck.  The blower is in excellent condition and is on the tractor currently.  The mowing deck has been a workhorse over the years.  No holes but could use some TLC, probably needs new spindles at some point and could use a couple spots touched up with welder also does NOT have any pulley covers/protectors (see photo).  Tractor has been an incredible tool, very solid and dependable and I'm certainly going to miss her when she's gone.
      Recent maintenance: replaced the plugs this summer, fluids as needed (hydro has about 100 hours on fluid/filter; oil was done in the spring and has about 25 hours on it).  Battery is about 3 years old as are the tires, Terra Trac tires on the rear and turfs on the front.  The seat (with arm rests) isn't in great shape.  I've got a cover for the seat, never used.  It's never really bothered me but new seat cover is included in sale as are 4 hub caps, chains for the rear tires, and some misc spare parts (see photos).
      I've owed this machine about 8 year and put ~350 hours on her.  She's not a show piece but could be restored.  Sheet metal is generally in shape, no rust however the hood does have a couple dings in it.
      I'm only selling because I'm trying to help my son get a small lawn care business started and looking to move to a zero-turn.  The 60" deck is too large for our trailer, the mowing deck lacks pulley safety shields, and we'd like something that mows faster.  My only complaint with this machine is the top-speed (which isn't great when comparing to today's machines) otherwise she's a beast.  They don't make them like this anymore.
    • Upnorthman
      By Upnorthman
      314-8 In great shape. Used for mowing more than anything. Bought it a few years ago but got a new tractor. I used the blower very little and it sounds like it needs a bearing on it. Runs well. I have new chains I've not put on yet and extra belts.
    • Trouty56
      By Trouty56
      Tractor vs. Implement cross reference chart for models from 1955 - 2000
      110 pages 513.43KB
      This chart lists the original attachment model
      The model that replaced the original model
      The model that was available when the list was made
      Often many models between the last two are not listed.
      You must go from year to year and follow the model numbers to see them all.
      For a complete list of models click on the magnifying glass in the Search box. Enter DNA in the Search box and select Files from the drop down menu. Two pages of 33 results will come up in random order. Find the attachment you are looking for and click on it. The DNA for that model of attachment will come up. Look for the model of your attachment in the DNA list. They are organized from earliest to latest.
      OR
      Search the Files using a model number you know will work. Look through the results for DNA in another file name for the same item. That will have the full list of models.
      STD for a model indicates that attachment was standard equipment that came on that model of tractor.
      Mistakes in the online attachment list @ Toro. The Attachment Interchange is correct but confusing and the source of the mistakes.
      1970 *VS           rear discharge mower deck                             5-7362 is correct replaced by 5-0610 both CCW rotation
      1971                  rear discharge mower deck                             5-0600 - CW spindle rotation fits long frame tractors only
      1971 *CG-7 & 8 rear discharge mower deck should be model 5-7362 - CCW spindle rotation
      1972 *CG-7 & 8 rear discharge mower deck should be model 5-0610 - CCW spindle rotation
      1973 *VS           rear discharge mower deck should be model 5-0611 - CCW spindle rotation
      1970 *VS          side discharge mower deck                             5-2365 is correct replaced by 5-0700 both CCW rotation
      1971                  side discharge mower deck                            5-0710 - CW spindle rotation fits long frame tractors only
      1971 *CG-7 & 8 side discharge mower deck should be model 5-0700 - CCW spindle rotation
      1972 *CG-7 & 8 side discharge mower deck should be model 5-0701 - CCW spindle rotation
      1973 *VS           side discharge mower deck should be model 5-0702 - CCW spindle rotation
      1974 Replacement rear discharge mower deck for the model 5-0622 (side discharge) is wrong - should be 65-36XR01
      *Models using a vertical engine crankshaft
