DeHart16 37 #1 Posted February 6, 2016 Doing my first restore of any kind on an 854. The engine and pretty much everything was good, but she was dirty as hell, not much paint left, and needing some freshening up. Ive got got the rear wheels off and the hubs seem to Beverly easy to remove, already sliding about a quarter of an inch... So any reason I should pull the hubs? What would I be replacing once I get em off? Is it worth the time and effort if nothing seems to be wrong? Thanks is for any help! doug 1 Share this post Link to post Share on other sites
953 nut 65,164 #2 Posted February 6, 2016 If you are doing a repaint and the axle seals are not leaking then I guess there wouldn't be any need to remove the hubs. 2 Share this post Link to post Share on other sites
DeHart16 37 #3 Posted February 6, 2016 Cool thanks....I'll get some pics tomorrow morning. Turned my shed in to my shop! Share this post Link to post Share on other sites
Horse46 519 #4 Posted February 6, 2016 As above, andI would just check the woodruff key and the keyway to make sure thats ok, if so I would leave them on. And of course we want pictures Share this post Link to post Share on other sites
elcamino/wheelhorse 9,363 #5 Posted February 6, 2016 welcome to Red Square . We always want pictures, some members including myself can't read tooo good so we follow along by pictures. 2 Share this post Link to post Share on other sites
AMC RULES 37,256 #6 Posted February 6, 2016 Same tractor here... you just picked up? 2 Share this post Link to post Share on other sites
DeHart16 37 #7 Posted February 7, 2016 Yessssir...thanks for posting 1 Share this post Link to post Share on other sites
Don1977 605 #8 Posted February 7, 2016 If they have been sliding a 1/4" the keys and the ends of the set screws are worn. Pull the hubs and replace both. As for the seals have you checked the transmission to see if it's full. The best of these old machines has some water mixed in the transmission oil that turns it a dirty brown. Need to check that too. 1 Share this post Link to post Share on other sites
DeHart16 37 #9 Posted February 7, 2016 Yessssir...thanks for posting so I took my hubs off, now what?? Also so as you can see to the far left of my photo the previous owner did some welding...now I have to get this steering wheel of before I can get the entire tool box, gas tank stand off.... Alright pic is on its side? Share this post Link to post Share on other sites
Achto 31,527 #10 Posted February 8, 2016 Now that you have your hubs off I would check to make sure there is no damage to the key way in the hub. If your key way is damaged you could run the risk of damaging the axel or breaking the hub in the future. Same thing could happen if the key is wore. In the picture you can see how the key way is wore on this hub. If yours is wore I would replace it. Good luck with your project! Share this post Link to post Share on other sites
DeHart16 37 #11 Posted February 8, 2016 Each of my key ways are what I would consider slightly worn. Here is a pic of the worse of the two...does this need replacing? What are my options? I really don't want to replace if it does need it. Share this post Link to post Share on other sites
WHX?? 56,030 #12 Posted February 8, 2016 Doesn't look the worse might be ok with a new key if this girl isn't going to get worked hard. Try to position the hub back on the axle in a slightly different spot. Drill & tap for another set screw 90 deg fron the old one is something guys have done too. Share this post Link to post Share on other sites
Achto 31,527 #13 Posted February 8, 2016 I would agree, yours don't look too bad. A second set screw like WHX6 suggested would also be a good idea. Share this post Link to post Share on other sites
DeHart16 37 #14 Posted February 9, 2016 Thanks for the help, I'll get some new set screws for it and get them all cleaned up....next up is getting this steering wheel off..... Share this post Link to post Share on other sites
can whlvr 994 #15 Posted February 12, 2016 good luck on wheel,ive had to do restores and leave the whole steering console as one because coulnt get wheel off,some guys put the whole unit in a press if you get the pin out Share this post Link to post Share on other sites
