nickj21 20 #1 Posted February 6, 2016 I need help figuring out if a raider 10 hood would fit on a charger 12? Is the height and length and everything the same? Please comment. Thanks! Share this post Link to post Share on other sites
daveoman1966 3,884 #2 Posted February 6, 2016 Since they are the same style tractor they should swap equally. I have a pic of each, but not good enough to give you 100% confirmation. Here is a charger 12 hood....looks the same as the R10. Share this post Link to post Share on other sites
nickj21 20 #3 Posted February 6, 2016 Sorry forgot to add mine is a 1972 and its a different style hood than that. Just now, nickj21 said: Sorry forgot to add mine is a 1972 and its a different style hood than that. Thank you though! Share this post Link to post Share on other sites
neil 2,415 #4 Posted February 6, 2016 I'm pretty sure they are universal , they all have the same hood stand & the chassis is the same size so would allow the changing of hoods. I prefer the earlier hood . 1 Share this post Link to post Share on other sites
daveoman1966 3,884 #5 Posted February 6, 2016 Is the charger 12 also a 1972? ok, if so. but earlier chargers had a hood as in the pic above. Your R10 hood look shaped like this pic? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,373 #6 Posted February 6, 2016 1972 Raider 10 model 1-0301 used 9699 hood (5 grill slots) replaced by 114289. These were used 1970-1982 with the last being the 1982 Model SK-486 It was likely 1975 that the 114289 was introduced 2-piece hood and grill joined with four 5/16"-18x1/2" self tapping cap screws and two 105038 grill plates I have a 1977 and 1982 hood and they are not bolted together so the 2 pieces may have been reserved for parts only for easier shipping. Garry Share this post Link to post Share on other sites
nickj21 20 #7 Posted February 6, 2016 11 hours ago, daveoman1966 said: Is the charger 12 also a 1972? ok, if so. but earlier chargers had a hood as in the pic above. Your R10 hood look shaped like this pic? I actually have a charger 12 and was wondering if a raider hood would fit because i cant find a hood originating from a charger. 11 hours ago, daveoman1966 said: Is the charger 12 also a 1972? ok, if so. but earlier chargers had a hood as in the pic above. Your R10 hood look shaped like this pic? I have a charger 12 and i cannot find a hood from a charger but the raider 10 hoods look the same. But yes that is the hood i need Would this be the right hood? Share this post Link to post Share on other sites
Cole J. 71 #8 Posted February 15, 2016 Here is a charger 10 hood Not the best pic Share this post Link to post Share on other sites
