ztnoo
GT 14 rear wheel hub
ztnoo
Look at this GT 14 hub pulling from Wheel Horse Junkies https://www.facebook.com/groups/263966625951/
Notice the flattened front tire.......more mass resistance to moving.......better than chocks, IMO.
12745405_1152785714746633_19732324949295
Look at what this gent successfully pulled this with...... a hope, a prayer, and maybe some adult beverages. Yikes!!!
Looked real flimsy to me.......pretty scary stuff.....
He didn't bust the hub, and didn't get injured.
Definitely a home brew solution that fortunately turned out OK.
12729087_1152027604822444_45428283070474
ztnoo
OK gentlemen, after a long delay caused by various diversions, obligations, distractions, some procrastination, enjoying life after my first monthly Social Security check three months after my 67th birthday, and picking any other topic you care to choose, I'm back on this project.
After finally getting those reluctant and remonstrative wheel hubs pulled, my immediate focus now is to attempt to getting the axles cleaned up (polished clean is my objective) before draining the tranny oil and digging those oil seals out.
My theory and concern about ultra clean, rust free, and polished axles serves two purposes.
1.  Polished and mirror like axles will insure minimizing damage to the new seal when they are slid over the axles and tapped into place in the axle housings.
2.  Mirror like axle finishes along with the hub bores being honed clean (see pics below text) and the judicious use of anti-seize compound upon reassembly, will ensure trouble free installation and possible removal in the future (if ever required).
Here's my current problem. The left hub (that moved inward last fall during yard work), proved the easiest to remove from its axle. My theory is the movement inward broke the rust bond between the axle and the hub bore. The woodruff key aligning and locking that hub radially was exceptionally easy to remove. A couple of taps with a awl in the axle slot end, and it popped right out.
Not so with the right side woodruff key. I have intermittently, since my previous post, applied alternating rounds of heat to the axle, liberal amounts of Kroil penetrant to the area of the key, and on occasion, lightly tapped and punched the key (not wanting  to intentionally damage it or the axle), and applied ice to the woodruff key after applying prolonged heat to the axle.
Nada. Nothing. No go. No detectable movement or even a slight willingness to move.
I'm really befuddled about how to get this one woodruff key removed from the axle without  #1 damaging the axle, and #2 damaging the key itself.
Do I need to be more aggressive "having at it" with a different technique, different procedure, a specific specialized tool? Anything? Anyone?
I'm determined to get the woodruff key removed because it prevents me using the technique I intend to employ to get those axles where the hubs were located for years looking brand new, before reassembling the hubs to the axles.
These woodruff keys are unlike anything I have ever seen on a consumer type residential product (see pic below text). They are remarkably massive in size being 2 inches in length and approximately 9/16" in height (from the upper flat portion of the key to the widest part of the radiused bottom of the key. This affords lots of surface contact area in mating with the axle slot. This is what gives them their remarkable strength and very securely insures preventing rotational movement around the axle by the hub. I'm not sure what type of steel they are fabricated from, be they are extremely hard. All my banging and clanging the one in question has made little impact on marring its surface. It's the fact because the key is so massive with considerable surface contact area with the axle which creates enormous strength, but also provides lots of surface area for rust/corrosion bonding with the axle.
So to all the learned experts residing here a RS, I'm in need of some serious expertise and direction to get this recalcitrant woodruff key removed so I can go about my intended goal of polishing the axles and changing the seals without risking damage to the seals themselves. What say you, gentlemen?? Have any secret technique, prayer, tool, or voodoo magic which proves effective against reluctant woodruff keys?
Regards,
Steve
GT 14 woodruff axle key:
IMG_0508.JPG.2e3acb194308a3ab76998b146c9
Cordless drill with Dremel 503, 3/8" x 1 1/8" 120 grit flapper wheel used for hub honing. Dremel tool itself not powerful enough to rotate flapper via Aldon's suggestion.
56d98a764137a_IMG_0509(2).JPG.afdedcbe58
1 1/8" flapper diameter is a perfect fit in hub bores for honing
56d98ab3adec3_IMG_0513(2).JPG.2e52b49469
Edited by ztnoo
Aldon
I know you have likely done this but with mine, it took a pretty harsh rap with a punch at a fairly sharp angle to break mine free. As you look at the hand drawn pic, the angle I had success at was at the arrow point. When it broke free it shot out and ricochet off tranny and I had to hunt around for it:-)
image.thumb.jpeg.5d129732704301fcf20b95e
  • Like 3
ztnoo
Thanks Aldon.
Yeah, I've basically done that too, but maybe I just need to do more of it, including immediately after heating the axle with my mapp gas torch.
I'll have another go at it.
thumbup.gif.03d17074eb2b80663baa9185498f
oldredrider
Aldon's method is what you need to follow. Just smack it hard; it will let go. Wear eye protection "just in case".
TDF5G
RS is a great forum!  I must say, I learn new things here everyday it seems.  Today I learned the definition of  remonstrative  and recalcitrant!  I had to look 'em up.
:mellow:
Edited by TDF5G
ztnoo
bookworm1.png.338a1b4c015f8a78f9b20efe3f   There's not a thing wrong with being a bookworm occasionally!     thumbup.gif.03d17074eb2b80663baa9185498f
Edited by ztnoo
can whlvr
ive had to use my dremel and cut the old key,carefully to not touch the axle at all,sacrifice the 2.00 dollar key to save everything else
ztnoo
Well............I've banged, clanged, hammered, heated, sprayed Kroil, & cursed most of the afternoon.
Even went and bought a variety of new hardened punches to attack this extremely obstinate woodruff key.
Eventually, I mixed a stiff Bacardi & 7 Up, and digressed to a more contemplative mindset.
palm-tree-on-beach-chaise-lounge-and-coc
I'm convinced the enormous size of the key and surface area it exposes on the axle slot, is the problem.......well..... rather the surface area that was exposed to moisture infiltration.......and then rust corrosion.
At this point, I'm really, really frustrated.
This sucker is REALLY, REALLY STUCK.
I'm referring to an almost WELDED type of "stuck".
I absolutely have to get this key off this axle ....
However, the one thing I DO NOT WANT TO DO is damage the axle or the key slot.
I might be willing to sacrifice the key a la can whlr's suggestion by having at it with a Dremel cutting disc.
I would prefer not to take that approach, but may have to in the absence of other advice or suggested procedural mechanical solutions.
I'm hoping the learned, experienced mechanical gurus and sages will offer their counsel and weigh in on this topic.........sooner, rather than later, por favor.
Steve
Edited by ztnoo
Aldon
16 minutes ago, ztnoo said:
Eventually, I mixed a stiff Bacardi & 7 Up, and .....
Consider two suggestions. Actually 3.
1) have another Bacardi:-) you've earned it!
2) consider drilling and tapping a hole 3/4 the length of the key towards the end of axle and find a high quality bolt to screw into it and use as a leverage point. In combination with punch from side on key.
3) if that does not work, I would get a dremel diamond blade and make a relief cut down the length of the key as deep as the blade and try not to cut into axle. Use the other key as a reference. Once the relief cut is done, use vise grips or stout clamp mechanism to crush the two sides together to break side tension in keyway. Then if still not free, try the punch again as at this point as resistance should theoretically be less.
Barring these, the only option is to grind it completely out if you wish to save the axle in my opinion. But luckily you have many on forum who may have other ideas and opinions.
daveoman1966
With the axle resting on a SOLID...immovable...flat surface (jackstand ok), hold the FLAT side of a small ball-peen hammer onto either outside edge of the half-moon key.  Now, with a BIG BIG BIGGER hammer, violently strike the ROUND end of the ball-peen hammer head.  This is an attempt to 'roll' the key out of the slot...or at least get it started.
This MAY take a couple applications but has always worked for me, without damaging the slot in the axle.  It is likely that you will flatten one side (end) the half-moon key and need to replace it.
  • Like 3
N3PUY
NO, NO, NO!!!!!!   Never strike a hardened surface with a hardened surface!   You'll put an eye out!
DennisThornton
What Aldon said.  Or take a cold chisel parallel to the shaft, catch the edge and give it no choice!
grine_22
Anyone ever heard of or tried soaking stubborn rusted parts with THE WORKS toilet bowl cleaner? We use it around the farm from time to time...
DennisThornton
Most any acid will eat away at rust. Vinegar does a surprising good job though not as fast but without the downsides of hydrochloric and other acids.  I use those too!  Just pointing out some options.
Edited by DennisThornton
removed "ly"
ztnoo
Dennis,
I have NO CLUE about "removed "ly"  ".
Could you please enlighten me about that statement???
Steve
DennisThornton
29 minutes ago, ztnoo said:
Dennis,
Steve
"Mostly" became "Most".  Guess that would have been more descriptive.
ztnoo
Dennis,
10-4
Comprendo.
Thanks for the clarification.
Regards,
Steve
ztnoo
An update from elsewhere:
Wheel hubs and axle woodruff keys have become my two most hated things to deal with in real life.
Give me a couple of weeks, and it will probably be something else.
Regards,
Steve
Aldon
Any time I start to get a big ego or start thinking I have it really good or otherwise too big for me britches, I just have to head out and try and pull a hub, flywheel or pulley off an old wheel horse and it brings me back down to earth and I realize I am only a mortal human being. Oh..and steering wheels are also quite humbling.
ztnoo
yeah......45 to 60 year old Wheel Horse tractors can make the most intelligent, "with it", tuned in, handy, mechanically inclined guys feel like a bumbling, idiotic, dufus in short order.
Count to ten, click your red shoe heels together, and you'll be with Dorothy in Oz...........................where there's a Horse of a Different Color.
I've worked on lots of different mechanical things during my lifetime, but right now, in the space I occupy in the great scheme of things, I'm about as perplexed and frustrated as I've ever been.
Who described this as a "fun" and enjoyable hobby?
I'd like to have a friendly, casual, non-confrontational conversation with that enthusiast.
The only good things going for me with this project right now is I got the engine to fire again and steering wheel comes off in flash.
Go figure............
Edited by ztnoo
roadapples
You will need some hair of toad & eye of bat & another Bacardi ..... Seriously I would try welding the head of a bolt, maybe 5/16 x 2", to the key. Tap on the bolt while still hot. The shock from the heat of the weld should help and you`re going to replace the seal anyway. Have done this in similar situations, although not this particular one....yet  :twocents-02cents: good luck..
ztnoo
Woodruff key update:
I took daveoman1966's advice and fully supported the axle I was to work on, the right side axle.
Since I had absolutely no luck moving the key after days of mapp gas torch heat cycles, liberal applications of Kroil, a variety of different punches, several hammers, I finally threw in the towel and decided my only hope of getting the woodruff key off the axle was to try center cutting the key lengthwise and attempt to collapse the sides until the key came out.
I actually started the cutting yesterday afternoon and was very cautious and deliberate in my cutting, trying to avoid damaging the key slot and the area of the axle surrounding the slot. It is tedious work and I tired of it late in the afternoon and started back up this morning. On occasion, several times as I deepened the cut, I would stop and attempt to punch the sides of the key toward the center of the cut, gradually opening up on both sides.
I repeated heat and Kroil cycles a few more times and each time cutting a little deeper and continually making depth calculations using the good left axle woodruff key as a gauge compared with the depth on the cutting disc.
Finally after cutting a little more and flat punching both sides of the key, the key began to rotate upward in the slot on the side closest to the axle housing. I was then able to actually wiggle it with my fingers and it came out!
Eureka! Time for a celebratory Bacardi!
I have somewhere between 4-5 hours from start to success removal in the cutting and punching operation.
Interestingly enough, all my heat/Kroil cycles reveal NO PENETRATING effect in the lower half and bottom of the woodruff key. Dry as a bone. This sucker was definitely "rust welded" to the axle.
I then started the tractor and put the tranny in forward to spin the axles. I dressed them with #220 wet paper with WD40, the progressed to #320 wet paper with WD40 applied to remove traces of corrosion discoloration and lightly dress the axle, not unlike what you would do on a lathe. Granted the axle doesn't turn particularly quickly, but the fact they rotated allow me to evenly dress each one. I also ran a second flapper disc I had of the same type I had used earlier to hone the hubs lightly, once again. Remarkably, both hubs now slide easily onto each respective axle. Looks like progress to me. It's about friggin' time!
The right axle key slot near the top of of the slot needed some very light filing to dress the edge which had been dented slightly inward. I filed until the good woodruff key would slide about half way into the slot.
I decided to stop that procedure until I actually located and have in my possession the appropriate, new woodruff keys for installation, and alter the slot as need to fit easily.
So, it's time to clean things up a bit. Then drain the tranny and remove and replace the axle seals. I'm hoping that goes smoothly because I believe I've had more than my fair share of problems between removing the hubs and dealing with the obstinate woodruff key.
The workplace:        The cutting tools:
IMG_0516.JPG.02d6e29d061151bd2dec112d4d6    IMG_0519.thumb.JPG.1deebe037bea397c08b12
Comparative examples: Good used woodruff key vs. shot split key
IMG_0520.JPG.7000bd366aa2c6b151050ba88bcIMG_0521.JPG.8f8ff577ba536dec86ff432c70b
There has to be a supplier or two or three that has these large woodruff keys out there in the world of industrial suppliers.
These keys weren't made special for Wheel Horse. They had to have been picked from regular industrial stock and inventory.
What reinforces that theory in my mind is the woodruff keys aren't shown at all in the parts illustrations and parts listings..........probably because they aren't/weren't proprietary parts.......they're a generic part that was/is available. Maybe not at the local hardware store, but still accessible and available in general terms.
Aldon theorizes, and I think reasonably so, that it's highly like any Wheel Horse tractor with 1 1/8" axles likely had the same size woodruff keys to secure the hubs. How about you D Series owners out there??? What do your woodruff axle keys look like???
If I can just bump into the right supplier(s) who will sell in modest quantities......I don't need lots of 25 or 50. I might go for 10, if necessary.
The jargon used with the key sizing left me scratching my head a bit.
Finally I figured out the 2 3/4" spec referred to the diameter from which the key is machined.
Depending on the supplier, they may describe the key by the diameter from which it is cut, or another supplier may describe it by the key's actual length. On the surface you would assume they are two different keys when in fact it can be the same key......it isn't just readily apparent. Who among us deals with woodruff keys and their sizing on a daily basis. Almost NO ONE.
I got out my dad's old drafting tools and swung a 1 3/8" radius to draw a complete circle of 2 3/4".
My good key fits perfectly to that drawn radius.
1/4" (W) x .58" (H)  x  2" (L)  on a 2 3/4" diameter, full radius
IMG_0523.JPG.2ca9da8028cc179126b5f7b6468
This is like a Star Trek voyage with Captain Kirk and Dr. Spock........into the unknown world of woodruff keys..........
C'est la vie,
Steve
  • Like 3
Aldon
Congrats!!!!!
:greetings-clappingyellow::thumbs:
DennisThornton
I think that cycles of heat and penetrant, even Kroil, is mostly a waste of both heat and penetrant.  Heat insufficient to release the part only burns/drives away the penetrant and the insufficient heat does nothing to get the part out.  Yes a little heat and sometimes a little penetrant by itself will indeed sometimes release a part that's a little stuck.  But if long soaks and some rapping and hammer tapping (or POUNDING) won't free it then it needs some HEAT!  Not with a hair dryer, or propane torch but with something that will deliver at least red heat!  Now often that kind of heat can also melt adjacent parts or damage the temper of surrounding or attached parts so the trick is to use some real HEAT!  Fast and furious to heat at least part of the offending part to at least a dull cherry red, persuade it out and quickly cool the remaining.
For removing stuck parts, to me, "heat" means at least a dull cherry red HEAT, usually delivered by an oxy/acet torch.  I probably wouldn't have wrapped a wet towel around both sides of the axle but you could, then I would have very quickly heated the protruding part of that key to almost white hot, which would dull by the time I grabbed my chisel and hammer and I cannot have any other image in my head other that it coming out seconds later.
  • Similar Content
    • ztnoo
      By ztnoo
      Not sure this is in the right category, but here goes anyway.
      I have a hydraulic fluid leak problem which originally WAS NOT particularly noticeable or troublesome.
      Now is would be better described as a HEMORRHAGE.
      Some of you may remember me doing battle a year ago last winter with the rear hubs on my GT 14 to originally correct an issue with one which had slid inward on the left axle.
      In the course of that adventure, it was mentioned to me that might be an excellent time to replace my 47 year old axle seals.
      They were leaking somewhat, but were not what I would describe as an emergency or huge fluid loss problem.
      I decided since it was the middle of winter and I was messing with the hubs, the suggestion made perfect sense to do some preventative maintenance at a leisurely pace given the time of year.
      So I was able to complete my horrific hub removal/woodruff key battle, but managed do the axle seal installation without major drama.
      I had completely drained the tranny prior to axle seal removal and upon installing the new seals and a new tranny filter, filled with fresh Type A tranny fluid.
      During the middle of the mowing season last summer, I began to note my hydro ground speed response was a bit sluggish and slow.
      After checking the fluid level in the tranny, I noted it was low.
      The system is a 4 quart system and it required over a quart to bring the fluid up to proper level.
      I checked around a different locations of the hydraulic system for some obvious telltale signs of loss.
      The new axle seals looked great, no loss there. The hydraulic cylinder looked OK from what I could tell after hosing the area down and running it again after cleaning. Didn't appear to be any significant or apparently loss there.
      The hoses looked OK with no cracking or splitting, and their fittings seemed to be leak proof.
      However after running the tractor for a while in a stationary position and using the control valve which lifts and lowers the mower deck, I could detect leakage out of the top of the valve. The leakage was only coming from the top of the control valve in the area immediately below the valve lever itself.
      My assumption is since I replaced the axle seals and stopped any fluid leakage in those two locations, potential leakage problems in the hydro system have migrated to the next weakest point.........in this case the control valve (#8363).
      Unfortunately, I did not attend to this problem last winter as I should have (DUH!), being aware of the problem.......which of course continued the remainder of the last mowing season.
      So..........guess what? The problem for some reason has not resolved itself without my engagement over the winter. And now its mowing season.......and in the two mowing sessions I've done since getting my mule drive problem and deck gauge wheel axle support problems resolved after running over a 3/4" steel form stake, the leaking/hemorrhaging control valve seal is only getting worse. I once again added over a quart of Type A fluid before my first mowing this year to bring the fluid to proper operating level.
      I know it needs fixed meaning new internal seals need to be installed. The problem is how to get to the control valve to remove it or manipulate it in some fashion to install the seals on the spool valve and get it reinstalled in the control valve body without tearing the tractor half way apart.
      Lots of older WH tractors have the hydraulic control valve on the outside of the hood stand or some side area of the tractor generally on the left just forward of the the seating position and under the dash area, which would make servicing the spool valve a relatively simple procedure.
      Not so with the GT 14.
      The control valve is located between two tall, heavy gauge "C" shaped steel panels which sit on top of the frame rails.The hood stand mounts to these "C" channel members. There is about 5 1/4" of width between the C channels......not a lot of room for a guy with big hands and fingers to operate.
      My primary question is can the control valve and its primary operating part, the spool valve which has two seals, be serviced without completely removing the valve body from the tractor???
      Is it possible to manipulate the valve after removing the mounting bolts from the right side C channel in such a way to gain access (the spool is removed from the bottom side of the valve body by removing a snap ring), either from the top or the bottom of the tractor to successfully remove the spool valve from the valve body, replace the seals, and reinstall the spool valve in the body of the valve without removing all the hoses and completely removing the valve from the tractor?
      Without the tractor running, will there still be residual hydraulic pressure in the lines and in the system in general which would cause fluid to spurt out once a component is removed.........a hose or the spool valve itself for instance?
      The control valve is WH part # 8363 and I see that Lowell Scholljegerdes (wheelhorseman1000) has a seal kit for resolving this leakage problem with "Control valve seals #7788". The seals are very reasonably priced and readily available and will undoubtedly fix the tremendous leakage at the top of my control valve.
      https://www.wheelhorseman1000.com/product-p/00123.htm
      The problem is what all is involved to get to the valve for the repair and how long something like this might actually take to get the tractor back in service?
      One of my big concerns is the hoses which are now 48 years old. They show no signs of leakage now, but I fear if I start manipulating and moving them around too much messing around with the control valve, I'll create a whole new dilemma.
      The big problem is its right in the critical time of year for mowing season here in Indiana, and with the mass quantities of rain we have had the last week or so, once it turns 75 or 80 or more, I'm going to need to mow twice a week just to keep up. Since my GT 14 is my only tractor and my prime tool for mowing, I just can't afford to have it down for a prolonged period this time of year.
      If there's not a decently quick and reasonably simple removal procedure someone can suggest, I may just have to continue to keep the fluid level up in the tranny and control the mess of the leakage around the top of the valve as best I can until a drier time of year when mowing isn't a pressing twice a week issue. I might even have to just grin and bear it and keep adding fluid until mowing season is over in the fall. That assumes of course the hemorrhaging doesn't get disastrously worse than it already is.
      I'm anticipating once this particular leakage issue gets resolved, the next weakest spot in the hydro system will show up, but first things first.
      Any suggestions or words of wisdom anyone has to offer about this repair, I am completely open to listening.
      Thanks,
      Steve
      p.s.  I've attached a few pics below of the control valve and the affected area which is leaking for your reference.
      leakage area circled
      ***  Updated Addendum: June 1, 2017
      See my last post dated June 1 on page 2 of this thread.
    • ztnoo
      By ztnoo
      I've been looking for a replacement small General Motors pickup from roughly 25 years ago in reasonable shape for 4-5 months.
      After reviewing untold numbers of CL listings during the period, I ran across what looked to be a reasonable mileage example in good aesthetic shape within a reasonable driving distance from my location.
      It was listed on CL in Louisville. Not exactly the next county over (a three hour one way drive), but a good enough prospect, I decided to take a day road trip
      3hr 2min, 187 miles, per Mapquest.
      I was thinking.......OK Steve, you are wanting to drive to Louisville to look at a vehicle, so what if I couldn't find anyone (a local friend/neighbor) available on Saturday to go with me?
      Three strikes and I was out. Bingo. Reality sets in.
      My theory was, if it was something I really decided I wanted, I needed to get it out of Louisville THAT day. But with no drafted co-driver, I had a definite problem.
      In a eureka moment, I remembered Chaplain Manny, who I had never met, but with whom I have conversed extensively, not only here at RS, but on various WH FB sites, and by email as well.
      Manny was raised in Louisville, so I instinctively knew he would be an excellent guide and pathfinder in a metropolis I had no familiarity with, other than passing through on I-65 to go to Florida.
      So, I messaged Manny on Friday with my situation and proposal and asked if he would be available to assist me for a few hours on Saturday. He now lives east of Jeffersonville (across the river from Louisville, in Indiana) in a very small rural town.
      He replied and told me he was available to help me, given his wife and young son were away at a wedding he wasn't attending.
      I explained the situation generally, and to my amazement and luck, Manny agreed to help me go into Louisville on my long bed S-15 quest.
      I arrived a little after 9 am at Manny's residence (following a three hour drive) and Manny proceeded to guide me into the bowels of Louisville.
      Traffic was horrific for some reason on Saturday morning on both southbound bridges over the Ohio River into downtown Louisville. Manny speculated there had to be some big event going on downtown that morning, but we never did learn what it might be. I would have definitely lost my cool sitting and waiting for traffic to start moving and the stress of trying to navigate the unfamiliar interior of a major urban jungle. But Manny took it all in stride and we eventually maneuvered around the bottlenecks and we got to the desired address in an area of town known as Germantown.
      So the short of it is, I bought the truck because it was in excellent shape for a 1990 model with reasonable mileage given its age, and Manny drove the station wagon while I followed in the S15 and we went back north across across the bridge over the Ohio River leading the way back to his place east of Jeffersonville. Generally speaking, the theory "move your feet, lose your seat" applies to CL items, because they can move very quickly and you usually have to have your ducks lined up and be ready to act promptly, or there's a high risk of losing your chance. With Manny's help and assistance, I was able to achieve my goal.
      Manny let me park the truck at his house until I can draft a friend into a day road trip to go retrieve my little S15 jewel later this week. When we got back to his place and he showed me his Wheel Horse collection and ongoing projects and we philosophized about life a bit before I left.
      Manny is a great caring and helpful person with a warm and outgoing soul. He has considerable health issues for a male of 56 years of age, but he does his best not to allow that to distract his quality of life and daily routine. I now consider him to be a friend and buddy and not just a correspondent........having met through our mutual interest in Wheel Horses, GT 14s in particular.
      Steve
      ___________________________
      Manny & me.
      Manny in front of my purchase.
      My "new" S15.
    • ztnoo
      By ztnoo
      I've discovered the main engine pulley driving the hydro pump seems to be a bit loose.
      I need to pull the clutch and associated pulleys off to have a look at what's going on back there.
      May be just a loosened allen screw mounting the pulley, a bad key, a bad pulley bore, or some combination of all three.
      Is the clutch mounting bolt going into the crankshaft a right hand thread, or a left hand thread?
      Anyone have a quick answer?
      Steve
    • ztnoo
      By ztnoo
      I have a Kohler K341 on a GT 14 tractor.
      Its always had the typical .....what are they called?........pepper shaker muffler? on the tractor.
      I've had to replace them several times....they seem to just eventually burn up.
      I can honestly say even from day one whenever I installed a new muffler of this type, I really couldn't tell that it really muffled much noise, maybe a little, but very little.
      As usage time goes on, they all got nothing but louder.
      Of course, part of this is the sheer displacement of the motor......35.9 cu. in. = 588 cc. Think of it in terms of a slightly bored out Norton Manx 500 cc thumper with an open megaphone exhaust. Deafening! You don't want to be standing 8 or 10' behind a Manx when it being warmed up and the throttle is being "blipped" to do that, without ear protection.
      These older flat head engines seem to be much louder than the newer OHV engines which are common in lots of equipment now.
      I've owned and used this tractor for 35 years now, and I guess I'm beginning to become somewhat of a crotchety old senior, but its becoming annoying to me (the operator), and I in fact had one neighbor that ragged me out over the noise.
      It may be because they have a pool and spend a fair amount of time outside, and the pool is about 10-11 feet from a chain link fence that divides the properties.
      I'm really not that worried about the neighbor nearly as much as I am myself, or should I say my hearing.
      I already have hearing loss from years of firing pneumatic nail guns and listening to compressors and heavy machinery running on job sites.
      What are you other K341 owners using and doing to get more muffling accomplished?
      Surely there has to be a more reasonable solution which will allow you to hear yourself think after an hour or hour and a half of operation.
      Is there a viable, positive solution for this problem so my ears and head don't ring for an hour after just mowing my lawn?
      Regards,
      Steve
    • ztnoo
      By ztnoo
      As many of you know, I've been in a prolonged battle with the rear hubs, woodruff keys, and oil seals on my 1969 GT 14, Model # 1-7441.
      I'm to the point of installing the new SKF oil seals today as soon as I can round up one more PVC fitting to properly size it to my seals for tap in installation.
      After that, its spin on the new NAPA 1410 hydraulic filter, and then fill with ATF.
      When I drained the tranny, I measured and computed the volume of ATF taken.
      It was right at 128 oz. + or - maybe two ounces. The volume spec says 4 qts. (4 qts. = 1 gallon = 128 oz.)
      So I know I was within spec, and wasn't losing large amounts of fluid, although I have a couple of random minor seepage locations on the tractor.......mostly around the control value which raises and lowers the mower deck.
      ATF is always what has been in the tranny, so that's what's going back in.
      My reason for caution regarding what to use specifically is probably more a matter of jargon and my understanding of terminology than anything.
      Of course, since my GT 14 was a first model year tractor, Type A transmission fluid was specified in all the literature.
      Type A is no longer available, but it my understanding is that equates with Dextron II.
      But isn't Dextron II now an outdated designation?
      If so, what should I be putting back into this Sundstrand  90-2062 tranny to ensure continued adequate trouble-free lubrication???
      I have more than a little angst over wanting to make sure I used the right product in this transmission.
      The changes in products over the years makes it very confusing for those of us who only occasionally wander in and out of discussions like this and automotive/mechanical related jargon and word usage generally.
      So gentlemen, what are your specific recommendations on tranny fluid to use in my Sundstrand, and is there any particular brand any of you favor over another?
      Or is it pretty much the case that ATF is ATF is ATF, the world around?
      Looking forward to your suggestions and recommendations.
      Regards,
      Steve
