Countdown To Christmas!
Guest fireman
D200 Hydraulic System
Guest fireman
Hey All
I picked up a Brantly Loader for my D200. Will the main pump supply enough gpm and pressure to run the loader? I'm not sure of the requirement for this loader, but i would assume it is close to the ARK. I don't have a 3 point hitch "yet" but the lines are there. Worse comes to worse I cold fab a bracket and mount a pump and run it off the front PTO.
Thanks,
Jeff
.5racer
Most of the D's ran the pump under where the mower deck is I believe by a belt useing the same pulley's the deck used.
pond195520032003
Jeff, as stated the loaders have their own pump mounted to the front under the grill with a belt that runs up to the pto!
dont believe you can run a loader off the tractor hydraulic system and wouldent be a good idea anyway!
as far as i know brantly never made a front end loader :hide:
i know they made the back hoes, that fit the D's aswell as others!
you probably have an Ark or a Kwik Way :hide:
the only others out there are Danco, and Johnson :D
Guest fireman
Pond,
It is a Brantly. Got a big old sticker right on the side. Brantly Manufacturing made loaders and backhoes for Bolens and JohnDeere also. Looks almost exacly like the ARK. See this link:
JohnDeere wih Branly Loader and Backhoe
I am going to fabricate a bracket for a pump and run it off the front PTO as it should be.
pond195520032003
ok you got me there :D i had forgot about the bolens loaders :hide: and even have that same picture saved to my computer :hide:
baerpath
Dragging this one up from way back
Just picked up a Bolens with a Brantly loader on it, was wondering how close of a fit it was Jeff. Looks like almost the same tractor in the picture except it has no engine :)
Duane
fireman
Duane,
I ended up selling that D200. I put that loader on the C-81. The sub carriage is different but probably could be modified. I used a Kwik-way sub-carriage and modified the bottom of the uprights to mate it. It did fit well on the C but may be a little short lengthwise for the D.
