clip 185 #76 Posted January 28, 2016 WNYPC, thanks for posting my thread. It takes me forever to dig through my old posts to and find links to my threads. WNYPC, thanks for posting my thread. It takes me forever to dig through my old posts to and find links to my threads. Share this post Link to post Share on other sites
WNYPCRepair 1,924 #77 Posted January 28, 2016 25 minutes ago, clip said: WNYPC, thanks for posting my thread. It takes me forever to dig through my old posts to and find links to my threads. WNYPC, thanks for posting my thread. It takes me forever to dig through my old posts to and find links to my threads. I just wish I had found your thread before upgrading my lights, your bracket seems a little easier than mine. Share this post Link to post Share on other sites
js5020 111 #78 Posted January 28, 2016 Going from a Farmall Cub or any small farm tractor or compact utility to any GT is going to be a disappointment if you have the expectation of just blasting thru deep snow without effort. I use to remove snow with a compact and it would blast through just about anything, pure brute force at its finest with the 4wd, diff lock and 3-4000 lb weight. I rarely use the compact and snow duty has been transferred to the old 16 Auto, I prefer the ease of operation of the hydro, and the small size of the GT, with that said I do have the 16 Auto equipped properly for the job,,,, wheel weights, bar tires, tri ribs, chains (haven't used em yet), plow for snows to 8 inches, blower for snows over 8", and always put the snow way back so you never need to attack an old frozen pile. 1 Share this post Link to post Share on other sites
lodestonefarm 41 #79 Posted January 28, 2016 16 hours ago, WNYPCRepair said: I was looking for my thread, but turns out clip used the exact set I did. Thanks Share this post Link to post Share on other sites
clip 185 #80 Posted January 28, 2016 2 hours ago, js5020 said: with that said I do have the 16 Auto equipped properly for the job,,,, wheel weights, bar tires, tri ribs, chains (haven't used em yet) I've got a similar setup, but I think I'm going to prefer Turf Savers over the ag lug tires. I've got 50 lb weights and 2 link chains, but the ag lugs allowed some of the links to slip into the voids. I still had a few links on each set of cross chains riding on the treads, but I think traction will be more consistent with a turf tire supporting the full width of the chain. Will be an interesting test. Share this post Link to post Share on other sites
can whlvr 994 #81 Posted January 28, 2016 I forgot to mention that the guard venting looks very professional,i love all my horses,like nothing else,but when we get a big snow fall I just go straight for my skid steer,you cant compare what it can do,compared to a garden tractor but I still love cleaning up and doing smaller snow falls with the horses Share this post Link to post Share on other sites
SAM58 34 #82 Posted June 15 i WOULD RECHECK THE HYDRO FILTER, HYDRO FILTER DOES NOT HAVE A SAFETY CHECK VALVE IN IT LIKE THE OIL FILTER IT'S DIFFERENT THAN THE OIL FILTER. THIS IS WHAT I USE... Share this post Link to post Share on other sites
Gasaholic 390 #83 Posted June 16 21 hours ago, SAM58 said: i WOULD RECHECK THE HYDRO FILTER, HYDRO FILTER DOES NOT HAVE A SAFETY CHECK VALVE IN IT LIKE THE OIL FILTER IT'S DIFFERENT THAN THE OIL FILTER. THIS IS WHAT I USE... whew.. its been 10 years since last post , while you may make a good point, an OEM toro wheel horse filter should be correct and should not affect the power of the hydro.. Plus, 10 years later, have to wonder if the machine is still around with the O.P. Share this post Link to post Share on other sites
SAM58 34 #84 Posted June 16 Yes you are correct, I seen the date after posting. Not everyone uses WH filters… so I know my 2 € not worth much. Share this post Link to post Share on other sites
953 nut 69,324 #85 Posted June 16 @SAM58, you win the Lazarus award for having resurrected the oldest thread on Red Square today. 2 Share this post Link to post Share on other sites
