Regal_Red
Regal_Red
Regal_Red
I am hoping to find a plow for my WH 701.  What should I be looking/asking for? I am not seeing it as a part on the 701 manual.
Thanks for your help!
Edited by Regal_Red
wanted to add notifications.
RedRanger
Any short frame snow plow should work.  You'll also need a set of the rear axle plow mounts.
Plows are on Craigs List for about $100 and axle brackets are about $50.
stevasaurus
Here is a couple of pictures of the type of snow blade you want to find.  Notice the frame is straight from one end to the other and forms an "A". :)
squonk
PM Sent! I have a "Side Shifter " short frame plow! :)
Edited by squonk
  • Similar Content
    • morePEdal
      By morePEdal
      *16 HP Onan Engine, 665.4 Hours
      *8 Speed Transmission
      *48” Snow Plow- Works Great! Set up and READY TO GO BEFORE THE SNOW!
      *Nice 42” Mowing Deck, no rot or welds, smooth spindles
      *OEM Wheel Weights, 50 lbs. Each
      *Chains
      *Valves adjusted this summer, runs great!
      *Good battery
      *Tires All Hold Air
      *LED lights all the way around
      *Manuals included
      Bought a Honda tractor with 4WD and 4WS with deck, plow and snowblower so I don’t need this tractor.
      Cash Only!
      *WILL NOT RESPOND TO “IS THIS STILL AVAILABLE?”
      *COMING SOON:  Also selling a Wheel Horse 520H with a 2-Stage Snowblower. Check out that listing if you want a snowblower garden tractor!
    • cbj75
      By cbj75
      I have a 1975 D200 Wheel Horse with front mount dozer blade, package includes Wheel Horse Dump Trailer, 48" belly mower side discharge, Wheel Horse front and rear wheel weights, turning brakes, rear PTO and 3-point to 2" receiver attachment, and Brinley twin disc harrow. Rear luggage/rack carrier, All refurbished, sandblasted and painted Ford red in 2016. Lots of extra Wheel Horse parts included.
      Package price $3000.00.
      Bryce Johnson
      102 Anglers PT
      Mc Cormick SC 29835
      913-638-6788
      IMG_1962.HEIC IMG_1965.HEIC IMG_0279.HEIC
    • Donavon
      By Donavon
      Need ideas to convert my 1054 A Frame plow into a snow blower
      Any idea's?
    • captjack
      By captjack
      Ahoy!  captjack.  I went to Manhattan, Kansas and purchased three Wheel Horses.  Along with the machines were a snow plow and the required items to attach it to a WH.  I also have a set of concrete wheel weights.  The plow appears to be very slightly used. As I am a John Deere AMT collector, I have no idea what a fair price would be.  Could someone let me know and, also, I can deliver them.
      Thanks and stay safe.
      captjack
    • WVHillbilly520H
      By WVHillbilly520H
      @WHX24, @PeacemakerJack, @ebinmaine, @JCM, @shallowwatersailor, @pullstart, @Horse Newbie, @elcamino/wheelhorse, @Ed Kennell, and the rest of RS ....
      As I have mentioned before I would be getting snow removal tools for my Mahindra eMax 22, the whole package plow, blower and soft cab, I had purchased a Kubota set-up a couple years back with the intentions of modifying it to fit/work with it but after careful consideration decided just to sell it to help pay for the correct set-up built for Mahindra (by Berco in Canada), I ordered it the end of October and its showed at the dealer in PA right before Christmas and I just picked it up Friday, and today got the sub-frame (which both the plow and blower use so you can switch between with ease) assembled and mounting brackets installed on the tractor frame (the only thing I don't like is you have to switch these brackets back and forth between this and the mower deck mounts "not quite WH easy" but after a few times it may not be so bad ), then installed the sub-frame , snow plow and ran the hydraulic lines and plugged into the loader/sector valve. The cab and blower assembly will follow within the next few days/weeks. Pics and a little video of it in operation.
      20210110_163214.mp4
