jerrell 1 #1 Posted December 3, 2008 :hide: Hey guys, i was just browsing around and found this site looking for a regulator for my LP engine and thougt some of you may be interested. does not have a website but the name is U.S. Carburetions Kit Center. Has a lot of useful info for people who would like to get away from carburetion problems. forget about adjustments, stabalizers and clogged or dirty carbs or gas lines. no filter problems, plugs last twice as long, and clean oil,the oil can last twice as long because there are no carbon deposits. forget about adjusting float levels. sounds like an advertisement dosn't it. No . it's a chance to have an alternative to high gas prices and propane is usually cheaper than gas , it is here in arkansas. The only draw back to LP is the Tank placement, it is bulky and takes up a lot of space, i solved this by placing the tank at the back of the seat. I have two choices, use the grill tank or buy a 30 lb long horizonal for a 100.00 another drawback is when you run out of gas,(have another grill tank ready)Also i have the choice of using gas and LP with the same carb. or Natural Gas without changing carbs. I also bought an adapter that i can fill my tanks from the farm LP tank instead of going to a propane station. i found the site it is: www.propane-generators.com Share this post Link to post Share on other sites
