jimbo7921 9 #1 Posted December 11, 2015 Hey there i was curious if anyone has ever posted the dimensions of the pieces to build your own extension kit, ive been searching the site with no luck. I have access to a laser cutter at work so i just need need to make a cad file to cut my parts. Any help wood b appreciated thx jim Share this post Link to post Share on other sites
WNYPCRepair 1,923 #2 Posted December 11, 2015 (edited) There was a post with the lift extension part measurements just the other day found ithttp://www.wheelhorseforum.com/topic/60686-snow-blade-mount-dimension-needed/#comment-561165 Edited December 11, 2015 by WNYPCRepair Share this post Link to post Share on other sites
jimbo7921 9 #3 Posted December 11, 2015 Thx that will b very helpful. Have more questions about the handle though haven't been able to find a good enough pic that shows if there is a 1 to 2 inch bend in it like the one i have on my current handle. Wood anyone know the part number for the handle off the top of there head? Parts tree has decent pics for refrence if needed. Also was wondering the thickness of material of the back bracket. Thx jim Share this post Link to post Share on other sites
WNYPCRepair 1,923 #4 Posted December 12, 2015 (edited) I am using the handle that came with my plow, though I did have to mount it backwards, and use a few washers for spacers Edited December 12, 2015 by WNYPCRepair Share this post Link to post Share on other sites
jimbo7921 9 #5 Posted December 13, 2015 Does anyone know the thickness of material that the back piece with 3/4 bar is welded into? Im assuming its 1/4 inch but kinda impossible to tell buy any pics ive seen. Thx jim Share this post Link to post Share on other sites
Tankman 3,526 #6 Posted December 14, 2015 (edited) I cut one frame, towards the front. Added 12 ga formed two channels 4-1/2" long. Welded in place. The spacer. Formed two more 12 ga channels 'bout 10" long that fit into the existing frame, stitch welded. Added strength. The 1/8" dia rod for the angle release was short, bent a new piece which I picked up at Lowes or Home "Cheapo." All's working well, clears the swept front axle perfectly. The lift point was perfect and used the standard rear axle mount. Edited December 14, 2015 by Tankman Share this post Link to post Share on other sites
WNYPCRepair 1,923 #7 Posted December 14, 2015 (edited) On December 13, 2015 at 0:59 PM, jimbo7921 said: Does anyone know the thickness of material that the back piece with 3/4 bar is welded into? Im assuming its 1/4 inch but kinda impossible to tell buy any pics ive seen. Thx jim Let me know if there is anything I missed. Besides the overall length, which is 12 1/4" Edited December 14, 2015 by WNYPCRepair Share this post Link to post Share on other sites
jimbo7921 9 #8 Posted December 14, 2015 (edited) Thats perfect thx alot. The sides r just 1/4 flat bar right? Not likely gonna matter since i dont have the proper tooling to bend it, gonna have to weld each side up. Oops just seen the size of material. My bad Edited December 14, 2015 by jimbo7921 Share this post Link to post Share on other sites
lynnmor 8,384 #9 Posted December 15, 2015 Note that the round bars are not in the center of the flat sides. Share this post Link to post Share on other sites
WNYPCRepair 1,923 #10 Posted December 15, 2015 1 hour ago, lynnmor said: Note that the round bars are not in the center of the flat sides. Yes, they will line up with the existing bar in the plow frame Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,920 #11 Posted December 15, 2015 This A-frame extension used 81640 or 8-1640 for a model number 1990-1997 Garry Share this post Link to post Share on other sites
