elliot ness
Help with model no.
elliot ness
 I got a D series tractor, here is the model no. [1 0611 9 ]& the serial No. is [1035884 ] Help ?
gwest_ca
The model number is just 1-0611.
http://www.wheelhorseforum.com/search/?type=downloads_file&q=1-0611
The 9 on the end is not used but if you subtract 5 from that 6th digit you get the model year. 9-5=4=1974
You will see a 6th digit 6, 7, 8 and 9 on attachments at the time also representing the 1971, 1972, 1973 and 1974 model years.
Garry
Sea-Duck51
My D160 tag is 01-160S01-3157 does this make it a 1976,curious also tag below that is 9260,thx.
gwest_ca
This should explain what you have
Have added your serial number to the list
Garry
Sea-Duck51
Garry
Thanks,found the info helpful,appears that as I thought it is a 1979 ,according to Julian date 9260 9=year 260=day 160S01-3157 16=hp O=Onan S=Sundstram 3157=production number,sound about right?.
gwest_ca
1980 models would have been released in October of 1979 just like autos today.  This coincides with Wheel Horse's fiscal year that ran October to September of the following year.
The 1979 model number is 91-16OS01.
The 1st 1 is for garden tractor as opposed to lawn tractor which was 2
At the time the 01 was the parts list identifier.
You figured out the rest.
Garry
Sea-Duck51
Garry
 You are correct my good man,after closer examination the Julian Date is 0260 not 9260 so that does make it a 1980,can't get nothing by you fine folks..lol
gwest_ca
It seems the Julian build date concept was lost quite often at Wheel Horse. I can understand the confusion because they were building 1980 models in late 1979 and 1981 models in late 1980. This happened often so don't know which is correct in your case. Toro shows the last year for the D-160 as 1980 but others have shown up. These could have been stamped incorrectly also. Have added yours to the 1981 list also but it fits better in the 1980 list.
1980
1981
Perhaps the engine serial number would shed some light on this if it indicates the year of manufacture. An engine built in 1981 could not land on a 1980 tractor unless it was a replacement.
Garry
  • Similar Content
    • tractorboy79
      By tractorboy79
    • BuffaloD200
      By BuffaloD200
      '74 D-180
      My friction disc in gone on my clutch.  I saw the old post about making a new friction disc, so I'm not concerned about that.
      I managed to remove the front clutch plate and double v-belt pulley.  But I can't separate the two.  When I took the assembly off the spiraloc washer popped off on its own.  I HAVE READ THE MANUALS.
      So I should be able to just remove the pulley from the front clutch and continue with step 4.  The v-belt pulley is loose as all hell and flops around like a dead fish.  It seems to be hung up on a ring or bearing race.
      So my thoughts are grab a BFH or sparky the blue tip wrench.
      Is there an unpublished step 3.5, or some trick?
    • BuffaloD200
      By BuffaloD200
      Hey all,
      My '74 D180 has a lot of trouble pushing snow.  Weighted tires, but nothing else at this time.  I've found it gets stuck frequently and only one wheel spins.  Do these tractors not have a limited slip/locker arrangement?  How does everyone manage with the infamous one wheel peel?
    • BuffaloD200
      By BuffaloD200
      Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
      Same question for my 80 D200 as well really.
      Using the recommended 4L490W belt.
      Thanks
    • ihatephones
      By ihatephones
      I got a D-180 for $250, and the governor is messed up, the points won't open or close, and I took it apart and was being stupid and messed some stuff up in there, and now I need a new one.
      Where can I get one that's not on eBay for $200?
      I also forgot to say it was a Kohler K482, and I'll throw some pictures of the tractor in as a treat.
