Similar Content
By Epayne85
Hello all, I have a what I believe is a 36” tiller.
i can get a few pictures of it this afternoon, it rolls freely and appears in very good condition. It’s missing the rear hinge panel. I’m mainly interested in swapping for a box blade and other items depending what you’d have for the clevis or sleeve hitch or I’ll take best offer. Thank you. Also, I have a snow plow and the frame in which someone has modified for I believe an Atv or different tractor I’d be willing to let go for $50 or throw in towards the deal. The blade is in pretty decent shape and the angle mechanism works flawlessly. Again thank you.
edit* I will be able to get pictures Labor Day weekend, sorry for the delay if anyone is interested
By Mattgray
I am looking for a snow plow in the Western NC area, might be a long shot but iv checked marketplace and craigslist. No luck. if anyone has one or knows where I could get one. I believe I need a long frame one for my tractor. Thank you!! sorry if I posted this in the wrong spot. One year after owning my wheel horse and still running strong!
By Trouty56
Tractor vs. Implement cross reference chart for models from 1955 - 2000
110 pages 513.43KB
This chart lists the original attachment model
The model that replaced the original model
The model that was available when the list was made
Often many models between the last two are not listed.
You must go from year to year and follow the model numbers to see them all.
For a complete list of models click on the magnifying glass in the Search box. Enter DNA in the Search box and select Files from the drop down menu. Two pages of 33 results will come up in random order. Find the attachment you are looking for and click on it. The DNA for that model of attachment will come up. Look for the model of your attachment in the DNA list. They are organized from earliest to latest.
OR
Search the Files using a model number you know will work. Look through the results for DNA in another file name for the same item. That will have the full list of models.
STD for a model indicates that attachment was standard equipment that came on that model of tractor.
Mistakes in the online attachment list @ Toro. The Attachment Interchange is correct but confusing and the source of the mistakes.
1970 *VS rear discharge mower deck 5-7362 is correct replaced by 5-0610 both CCW rotation
1971 rear discharge mower deck 5-0600 - CW spindle rotation fits long frame tractors only
1971 *CG-7 & 8 rear discharge mower deck should be model 5-7362 - CCW spindle rotation
1972 *CG-7 & 8 rear discharge mower deck should be model 5-0610 - CCW spindle rotation
1973 *VS rear discharge mower deck should be model 5-0611 - CCW spindle rotation
1970 *VS side discharge mower deck 5-2365 is correct replaced by 5-0700 both CCW rotation
1971 side discharge mower deck 5-0710 - CW spindle rotation fits long frame tractors only
1971 *CG-7 & 8 side discharge mower deck should be model 5-0700 - CCW spindle rotation
1972 *CG-7 & 8 side discharge mower deck should be model 5-0701 - CCW spindle rotation
1973 *VS side discharge mower deck should be model 5-0702 - CCW spindle rotation
1974 Replacement rear discharge mower deck for the model 5-0622 (side discharge) is wrong - should be 65-36XR01
*Models using a vertical engine crankshaft
By Marc M.
Hi guys I'm new to the wheelhorse world and i recently picked up a for 416-H and I'm looking to buy/install a plow put on it. I have found one on craigslist but I can't tell if it will work on my tractor or not, it is a wheelhorse plow though. Can somebody please send a photo or even a video of how to hook up a plow to a 416 or equivalent tractor?
Attached is my tractor and the plow I'm looking at. Will it fix and what's it missing ?!
By MartinSweden
Hi,
I bought a C 120 model with a snowblade from an old lady. However i can't figure out how to to assemble the snowblade in the front of the c120-machine. I guess I am missing some sort of an adapter? It doesn't look like a standard blade according to pictures I've seen where you assemble a steel frame under the machine. The lady don't know how her husband used to assemble it. Does anyone have a picture/instructions how to assemble it and a picture of the assumed missing adapter (if needed)? I guess i need to go back to her barn and start looking for missing parts.
