Racinbob 13,286 #26 Posted November 17, 2015 He's got the wrong crew chief then. It's in the wrong direction. I agree with Mike. It's not hurting a thing. I know there things can bug a person but all I can come up with is that you have two right side spindles a fuzz off in the same direction 1 Share this post Link to post Share on other sites
Marv 996 #27 Posted November 18, 2015 Curious. If you measure from the top inside edge of the rim to the axle are both wheels the same?Marvin Share this post Link to post Share on other sites
mrc 1,122 #28 Posted November 23, 2015 hello men, first, thank you to all who took the time to reply. i really appreciate it. i was almost ready to fire up the torch and bend the spindle to my liking. i really hate to hack up things though. finally, i scrounged thru my parts stash and found yet another set of spindles. i swapped out the right side spindle and BINGO! now it was the same angle as the left side. the level confirmed this. the wheel looked "right" to my eye. i breathed a big sigh of relief. best regards mike in mass. 4 Share this post Link to post Share on other sites
Save Old Iron 1,576 #29 Posted November 27, 2015 you made mention early on how you exchanged a spindle assembly from another tractor and the wheel still had the same tilt. would this not mean the first spindle you swapped in is also crooked ? Share this post Link to post Share on other sites
mrc 1,122 #30 Posted November 28, 2015 save old iron: yes, that was my conclusion. odd thing is the spindles did not look crooked to the naked eye. first time i've run across this problem. i agree with some of you that on a garden tractor this was not a huge concern. vs. an indy car for example. still, it bothered me when i looked at it. mike in mass. Share this post Link to post Share on other sites
buckrancher 2,697 #31 Posted November 28, 2015 more than likely the spindles were not made correctly from the factory it's not unreasonable for parts to go thru the manufacturing process that are slightly out of tolerance but are still usable you could have a entire run of parts like a right front spindle that were over bent a couple of degree's but instead of rejecting the parts wheel-horse decided they could use them Brian 4 Share this post Link to post Share on other sites
pfrederi 21,306 #32 Posted November 29, 2015 I have purchased several used spindles over the years many turned out to be somewhat bent. Share this post Link to post Share on other sites
JP 141 79 #33 Posted November 30, 2015 Wondering myself, based on the pics....Is the front axle mounting pivot hole or bushing bad ? Maybe the frame bent just a bit ? Going to follow this to identify the issue...Nice problem ( not really) but we all will learn from this... Share this post Link to post Share on other sites
cleat 9,405 #34 Posted December 1, 2015 I have made up new front axle pivot pins for all of my 520's as whey were worn. Wheels did not sit crooked for this problem however, just made play in the steering as the axle moved instead of turning the wheels on very slight steering wheel input. Cleat Share this post Link to post Share on other sites
