mikehusky455 16 #1 Posted November 14, 2015 (edited) haven't realy had time yet to check into this gt yet working on everybodys snowblowers,but my gt don't have the lift lever for the 3pt hitch,could one similar from a woodsplitter work or is it specific to the tractor,thanks. everything always seems backwords using laptop as camera sorry bout that Edited November 14, 2015 by mikehusky455 Share this post Link to post Share on other sites
KC9KAS 4,741 #2 Posted November 14, 2015 This is the type of valve you need. On the GT-14 it mounts inside the tunnel by the motion control lever. Other models have them mounted on the left side of the "hood stand" like this one. 1 Share this post Link to post Share on other sites
mikehusky455 16 #3 Posted November 14, 2015 (edited) thanks.i got something here that I can make work ,now that I know what it looks like.,not trying to redo gt too look pretty just want to function,for plowing snow,and out in woods. Edited November 14, 2015 by mikehusky455 2 Share this post Link to post Share on other sites
KC9KAS 4,741 #4 Posted November 14, 2015 (edited) @mikehusky455 I have a GT-14 and added the 3 pt lift. I also added a 2nd cylinder and valve so the mid and rear lifts operated independently.There was a WH kit that mounted the additional valve on the left (outside) of the tunnel for the 3 pt lift, but I just made a plate and installed both valves inside the tunnel.It is very crowded in there and both valves have to come out to work on either, but that si the way I did it and have to deal with it! Edited November 14, 2015 by KC9KAS why didn't it notify mikehusky455? 1 Share this post Link to post Share on other sites
mikehusky455 16 #5 Posted November 14, 2015 that makes it easier for shure,dont even know what works and don't work,got to get electrical done then try everything else,am also getting the kohlor 14 with ohv ,haven't seen one that old with ohv. Share this post Link to post Share on other sites
fast88pu 3,313 #6 Posted November 14, 2015 KC9KAS would you happen to have photos of that setup ? I think thats what im going to have to do. My front rock shaft keeps breaking. 1 Share this post Link to post Share on other sites
Aldon 4,826 #7 Posted November 14, 2015 Ditto. Would like to see photos as I would like to do similar to mine. Share this post Link to post Share on other sites
KC9KAS 4,741 #8 Posted November 15, 2015 I will try to get photos Sunday. 1 Share this post Link to post Share on other sites
jeremi3210 688 #9 Posted November 20, 2015 Here is what I did with mine. The original one is the mid lift, the two on the side are for the three point and the snow blade angle. 1 Share this post Link to post Share on other sites
mikehusky455 16 #10 Posted November 20, 2015 nice job. Share this post Link to post Share on other sites
KC9KAS 4,741 #11 Posted November 29, 2015 @fast88pu @Aldon My rock shaft broke last year and I had to remove it and have it welded. As I was removing the cylinder (and control valve) Saturday I can see it hits in the full up ANF the full down position...Not sure why.... Here are photos of my valves. 2 Share this post Link to post Share on other sites
fast88pu 3,313 #12 Posted November 29, 2015 do you have any photos of the rear 3pt set up ? thanks 1 Share this post Link to post Share on other sites
