mikeeyre74 290 #1 Posted November 12, 2015 I have a parts tractor out front, a 1977 B60 8 speed. There's a guy near me selling an unknown vintage 310-8 with a broken frame for a song... I'm wondering if I snap that up if I can't put the two together and make a runner from them. Any ideas if the frames are significantly different between the two, I should I scrap this idea? Share this post Link to post Share on other sites
KC9KAS 4,746 #2 Posted November 12, 2015 Go for it....I would think it will work fine with minor problems.Someone else may have other ideas.!Measure the frame length from transmission to the front of the frame on each one. Share this post Link to post Share on other sites
cleat 9,403 #3 Posted November 12, 2015 If worse comes to worse, Wheel Horse frames are simple angle iron construction so repair should be easy for anyone with a welder.Cleat 2 Share this post Link to post Share on other sites
stevasaurus 23,861 #4 Posted November 12, 2015 (edited) Here is what the 310-8 frame looks like..here is the 77 B-60...can't seem to copy the B-60 frame. Anyway, it looks exactly the same except for the 2 back bars for the running boards. I think they are going to be the same length and everything. Like was said, it is an easy fix. Here is the link to the B-80...frame is on like page 5. http://www.wheelhorseforum.com/files/file/1030-tractor-1977-b-60-b-80-b-100-8-speed-iplpdf/ Edited November 12, 2015 by stevasaurus Share this post Link to post Share on other sites
953 nut 70,085 #5 Posted November 12, 2015 If the frame is broken my guess would be it will be where the foot rest bar intersects the frame, cut out from bottom and very weak. The other likely area would be the transmission mounting plate. Either of these could be repaired easily with a little welding. 1 Share this post Link to post Share on other sites
stevasaurus 23,861 #6 Posted November 12, 2015 Not sure what parts from the 310-8 you are looking for, but the engine, trans should bolt right on. The hood may even be the same length and height. Share this post Link to post Share on other sites
mikeeyre74 290 #7 Posted November 13, 2015 the guy says its the area right where the transmission attaches to the frame, so... I suspect that area there towards the back of the tractor, not so much the floorboard area. I should have mentioned that I guess. If it's just matter of welding, I think I'll grab it since you all are saying it's an easy enough fix. Thank's for the assist! 1 Share this post Link to post Share on other sites
KC9KAS 4,746 #8 Posted November 13, 2015 The trans to frame mount break is fairly common. There are several post on RS explaining the repair process.Go for It and repair It and have a nice 300 series machine 1 Share this post Link to post Share on other sites
fast88pu 3,402 #9 Posted November 13, 2015 The b series frame is missing the rear bar to go under the 300 series and you would also have to remove the belt guard tabs on the b series frame too. I put a 414 frame under a B100 because of frame rot on the b100. It was pretty simple. I also have a bent 300 series frame if your interested and local. Pm me Share this post Link to post Share on other sites
mikeeyre74 290 #10 Posted December 22, 2015 If anyone is still following this thread with any interest, it turns out the plate in the back of the frame to mount the transmission was too far gone to repair with a weld. We ended up cutting off the bracket from the B-60 frame and welding that to the 310 frame, because that was easier than fitting that rear most floorboard bar to the B-60 to end up with what I needed to repair it. Right now, I'm just finishing up putting on the sheetmetal and it's a really nice machine now. I really dig this M10 Magnum motor too. Strong and quiet, better than my B-80 worker is, anyway.. 3 Share this post Link to post Share on other sites
slammer302 2,157 #11 Posted December 24, 2015 Glad to hear that you were able to save it. 310-8 is a great horse Share this post Link to post Share on other sites
Brian01 481 #12 Posted December 24, 2015 HmM ....no pictures of your process/progress? Start to finish? Share this post Link to post Share on other sites
DennisThornton 4,773 #13 Posted December 24, 2015 Yeah. Come on Mike, share them here as well! You did a great job! Share this post Link to post Share on other sites
mikeeyre74 290 #15 Posted January 1, 2016 (edited) I can't. I have no room to upload them! how's that? That's her.. broken in half on the trip home. Some broken bits.. Here we're tearing it down... Edited January 1, 2016 by mikeeyre74 1 Share this post Link to post Share on other sites
mikeeyre74 290 #16 Posted January 1, 2016 Here's the broken frame, where the transaxle tore it off.. Here's some welding action! Starting to go back together now... Getting closer... 2 Share this post Link to post Share on other sites
DennisThornton 4,773 #17 Posted January 1, 2016 16 minutes ago, mikeeyre74 said: I can't. I have no room to upload them! how's that? That's her.. broken in half on the trip home. Some broken bits.. Here we're tearing it down... Mike, you did a great job of documenting this project. I'd like to save all these photos and the rest to follow myself for future reference. There will be many others that will now or later appreciate them. You saved a broken Wheel Horse and gave it a new life! This will solve your upload issues: http://www.wheelhorseforum.com/store/category/1-redsquare-support/ BTW, what's the gear driven hopper in the "Here's some welding action! " photo? That must have been a lot of snowbank pushing (pounding!) to have done that to the frame! Any signs of a seat belt or harness? Bent steering wheel? 1 Share this post Link to post Share on other sites
TDF5G 2,074 #18 Posted January 4, 2016 (edited) Thanks for the pics. And what Dennis said. You don't know how those pics may help someone else with a present or future project. Edited January 4, 2016 by TDF5G Share this post Link to post Share on other sites
