BairleaFarm
Hour Meters
BairleaFarm
Pricey little suckers for what they are. Do you all replace yours with toro ones or buy elsewhere? I bought on off ebay for the b100 and it seems to be working well. I just ordered a different brand off ebay for the b80
Teddy da Bear
I wanted to get one for my one tractor.
Saw them at the Rural King for about $125.
Don't know if you can use any one or are there
different types?
Jim_M
As long as it will handle 12 volts it will work.
sorekiwi
A lot of guys like the "Tiny-tach". Its a tach but it has an hour meter too. There are different types, - for some reason the Kohler one is "special". I think it'd be handy having a tach on the dash too.
http://www.tinytach.com/tinytach/index.php
BairleaFarm
This is the elcheapo one I got.
KyBlue
D your missin a bolt...
BairleaFarm
if thats all im missing than im doing good . :hide:
jerrell
I just saw one on a site that i am getting my regulator from, can't remember the name , will research again and post, but for 34.00 you get hr meter and tach, plus a life time garrantee. you mount with two screws and just wrap a tiny wire 5 times around the spark plug wire or wires for 2 cyls. a neat item. i bought the tiny tach and it's great for tuneing up a motor, and takes the guess work out of time when the oil needs changing.
pond195520032003
if thats all im missing than im doing good . :D
I dont think he was meaning off the tractor :hide: :hide:
mcwh1950
I dont think he was meaning off the tractor :hide::hide:
no he is missing the two washer . on the horse from the right side we hope. if not the left side is differ by 0.1/89
KyBlue
He Swiped that cover plate off the C160 - hour meter too, Im not to wild about the plate goin bye bye but the HR meter isnt much of a loss...imo not hung up on mhaving them.
BairleaFarm
How dare you accuse me of that. :hide: The c160 plate is hanging on my wall I think(ill get hat back to you next time i see ya) I forgot to grab it. Ive beleve ive also got the one that the regulator was mounted to but its broken. This meter came from ebay. I threw away the one that was on the C160. If you look under the hood there should be a digital one laying by the tank
KyBlue
Well if youve got it, my apology but after flipping thru your pictures (which i cannot seem to find again) it was a identical Hr meter, and if I recall you got the one that was on the C off Ebay.
thats the best photo I can find - dont rember where i found the other. if you have that plate great, if you need one, well we can fire up the plasma cutter and trim you one out
Try out the plow with that lil bit of snow we had??
